kirgudu Posted August 3, 2021 Share Posted August 3, 2021 Hello! Millage - 18000 km 2015 Tracer 900 From Japan I have Tuk-Tuk sound from my chain, and i want to change cam chain tensioner, but I cant found part number. All parts catalogs show 1RC-12210-03 or 1RC-12210-04. All of then is "Not available" not for order. What part number I can use? From 2017 or 2018 Tracer? B90-12210-00-00? Or may be mechanical tensioner? Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted August 3, 2021 Premium Member Share Posted August 3, 2021 Get a manual CCT Many available and cheaper without worry of failure APE Graves, etc 1 Link to comment Share on other sites More sharing options...
Supporting Member knyte Posted August 3, 2021 Supporting Member Share Posted August 3, 2021 There may be a recall available for your Tracer. I was told my FJ had the 4th iteration of the recalled tensioner. It still occasionally rattles, but it goes away after 10 - 15 minutes. Come to think of it, it hasn't rattled in many months. It sure did last year a few times - but went away. 1 2015 FJ-09 / FJR touring bags / oil plug mod / Evotech rad guard / SW Motech bash plate / VStream touring windshield / Seat Concepts: Sport Touring / Vcyclenut ABS rings (speedo correction) / Cosmo RAM mount Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted August 3, 2021 Premium Member Share Posted August 3, 2021 You shouldn't of said anything about it rattling... LOL I had the 2nd gen done under a TSB not a recall and it failed as well. MCCT is pretty much set and forget without concern Easy job when done in conjunction with a valve lash check/adjust. 1 Link to comment Share on other sites More sharing options...
Supporting Member knyte Posted August 3, 2021 Supporting Member Share Posted August 3, 2021 Fair enough, lol. I've heard the manual adjuster seems to solve it for good. Mine isn't bad enough to want to change it yet (so far so good, anyway). 1 2015 FJ-09 / FJR touring bags / oil plug mod / Evotech rad guard / SW Motech bash plate / VStream touring windshield / Seat Concepts: Sport Touring / Vcyclenut ABS rings (speedo correction) / Cosmo RAM mount Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted August 3, 2021 Supporting Member Share Posted August 3, 2021 As mentioned by others, there are several options for a Manual CCT. Here is one example for instance. 1 Link to comment Share on other sites More sharing options...
kirgudu Posted August 3, 2021 Author Share Posted August 3, 2021 5 hours ago, knyte said: There may be a recall available for your Tracer. I was told my FJ had the 4th iteration of the recalled tensioner. It still occasionally rattles, but it goes away after 10 - 15 minutes. Come to think of it, it hasn't rattled in many months. It sure did last year a few times - but went away. I have no recall, Tracer from JDM and Japan recall company doesn't work in Russia. Hello to Yamaha RUS. No sound after oil change, but after 3000-4000 km rattles again. 5 hours ago, 2and3cylinders said: Get a manual CCT Many available and cheaper without worry of failure APE Graves, etc Thanks! What manual CCT you recomend? Link to comment Share on other sites More sharing options...
Your_Boy_Yuriy Posted August 4, 2021 Share Posted August 4, 2021 3 hours ago, kirgudu said: I have no recall, Tracer from JDM and Japan recall company doesn't work in Russia. Hello to Yamaha RUS. No sound after oil change, but after 3000-4000 km rattles again. Thanks! What manual CCT you recomend? Hi there fellow Russian.... Well actually Ukrainian that speaks Russian. Mine started making noises too around 30,000 miles. I replaced it with another OEM tensioner from Revzilla during my valve clearance adjustment. So far the noise is gone but I should of replaced it with a manual tensioner. During the winters months I'll replaced it with a manual tensioner. 2 Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted August 4, 2021 Premium Member Share Posted August 4, 2021 13 hours ago, kirgudu said: I have no recall, Tracer from JDM and Japan recall company doesn't work in Russia. Hello to Yamaha RUS. No sound after oil change, but after 3000-4000 km rattles again. Thanks! What manual CCT you recomend? The one Dazzler provided a link to is cheaper than the APE I have. They're a simple device so any quality item will do. It's the install you just need to be careful doing... Link to comment Share on other sites More sharing options...
skipperT Posted August 5, 2021 Share Posted August 5, 2021 (edited) There’s 2 different part numbers because Yamaha made a running change to the cylinder head oil passages (at least in the us and Canada). you’ll need to order either item 6 or 15, plus a gasket. Are all your valve cover bolts the same? Or is the RH rear bolt different? your bikes definitely a 2015 with the original engine? -Skip Edited August 5, 2021 by skipperT Link to comment Share on other sites More sharing options...
quaxum Posted August 5, 2021 Share Posted August 5, 2021 Got this off the FZ09 forum. Hope this helps. Left old Right new https://www.fz09.org/threads/got-new-cam-chain-tensioner-just-wondering-if-this-is-correct.68297/#lg=attachment163552&slide=0 Link to comment Share on other sites More sharing options...
