Supporting Member maximNikenGT Posted September 16, 2021 Supporting Member Share Posted September 16, 2021 (edited) I stumbled across this video last night on motorcycle engine engineering which asked the question, why does Yamaha use a cross plane engine when the rest of the industry predominantly uses inline 4 configurations. It was a detailed background and walkthrough and I found it very educational as to why the cross plane design, although heavier to counter balance inherent engine design vibrations, was preferred by Yamaha. The video takes a look specifically at the crossplane four-cylinder configuration but I'm assuming that the performance benefits inherently remain the same when transferred to the Niken's triple cylinder cross plane (CP3) design. Edited September 16, 2021 by maximNikenGT corrected misspelling 2019 Niken GT "Motorcycles - the brand is not important, the fact that you ride is." Link to comment Share on other sites More sharing options...
peteinpa Posted September 16, 2021 Share Posted September 16, 2021 Using the CP3 designation on the tripple is a stretch. Each crank pin set at 120 degrees is normal. Now on the Yamaha inline 4 it is unusual how the crank is set up and is special. 1 1 Link to comment Share on other sites More sharing options...
OZVFR Posted September 16, 2021 Share Posted September 16, 2021 (edited) CP3 does sound better than "the new Yamaha comes with a Normal 3 Cylinder engine" Back n the 80's I had a Laverda RGS1000, it had a 180° crank triple that sounded better but vibrated so much that it had to have rubber engine mounts to keep it under control. Edited September 16, 2021 by OZVFR 1 Link to comment Share on other sites More sharing options...
peteinpa Posted September 17, 2021 Share Posted September 17, 2021 Forgot to mention on the FZ-07, MT-07, etc. The CP2 design is awesome! All vertical twins should be made this way. I was impressed when I had mine. If they could have made it 800 to 900 CC it would have been a keeper. The sound and power left "normal" vertical twins behind. 1 Link to comment Share on other sites More sharing options...
OZVFR Posted September 17, 2021 Share Posted September 17, 2021 The new Triumph Tiger 900 as well as the new 1200 coming soon both have a T plane triple. Much better sound than the CP3 and better power delivery down low. Link to comment Share on other sites More sharing options...
Fleng Posted September 17, 2021 Share Posted September 17, 2021 In the crossplane configuration the 3 ignition cycles are close behind each other (and then a longer time nothing). In the end, this delivers higher torque, which was the whole idea of the MT (max torque) range. Link to comment Share on other sites More sharing options...
OZVFR Posted September 17, 2021 Share Posted September 17, 2021 (edited) 1 hour ago, Fleng said: In the crossplane configuration the 3 ignition cycles are close behind each other (and then a longer time nothing). In the end, this delivers higher torque, which was the whole idea of the MT (max torque) range. You’re confusing crank angle with firing intervals. Crank is at 120*, but firing intervals are at 240*. No spaces in between. 240, 240, 240 and so on. They don’t fire 1-2-3. Not a lot different to a 4 cylinder with equal gaps. The Triumph T plane fires at 180, 270, 270. Or the Honda V4: 180, 180, 90, 270. Ahh, music to my ears. Sorry for all the edits, it’s Friday night and too many Wild Turkeys. Typing with one eye shut Edited September 17, 2021 by OZVFR 1 Link to comment Share on other sites More sharing options...
Wintersdark Posted September 19, 2021 Share Posted September 19, 2021 On 9/16/2021 at 6:13 PM, peteinpa said: Forgot to mention on the FZ-07, MT-07, etc. The CP2 design is awesome! All vertical twins should be made this way. I was impressed when I had mine. If they could have made it 800 to 900 CC it would have been a keeper. The sound and power left "normal" vertical twins behind. It is. Big part of why I got the T7 as a second bike. That CP2 is *wonderful*. Link to comment Share on other sites More sharing options...
Supporting Member maximNikenGT Posted September 19, 2021 Author Supporting Member Share Posted September 19, 2021 So I now see why Yamaha's CP3 designation gets ribbed from Lemmy at Revzilla: It does seem unusual that Yamaha would try to market an engine whose crankshafts inherently has to be configured 120 degrees apart. 2019 Niken GT "Motorcycles - the brand is not important, the fact that you ride is." Link to comment Share on other sites More sharing options...
Supporting Member maximNikenGT Posted September 19, 2021 Author Supporting Member Share Posted September 19, 2021 Ok, to try and better understand the inline three cylinder "CP3" design, here's a look at what the firing order looks like when connected to lights: 2019 Niken GT "Motorcycles - the brand is not important, the fact that you ride is." Link to comment Share on other sites More sharing options...
