Premium Member keithu Posted December 6, 2021 Premium Member Share Posted December 6, 2021 I'm trying to wrap up a valve adjustment. Of all the complex tasks involved in this project, it's the most basic thing that's kicking my ass: I can't get the new valve cover gasket positioned correctly. Really, I should have just left the old gasket stuck to the cover and re-used it because it was fine. I reused it the first time I checked the valves. But I bought a new gasket and figure I ought to install it just because. So the root problem is this: I install the rubber gasket in the cover, but then when I try to install the cover the gasket keeps falling out. I have some Lucas assembly lube for valve train components. It's kind of tacky so I was thinking of putting some in the gasket channel to stick the gasket to the cover. Anyone have a better idea? Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted December 6, 2021 Supporting Member Share Posted December 6, 2021 (edited) I use small dabs of high temp, quick set rubber cement/adhesive in several strategic spots, inside the cover groove. I leave it for 15min and the gasket stays put. Have the rad out as possible to give you space to work. Quick set liquid gasket should work too. Best of luck. Edited December 6, 2021 by piotrek 1 1 Link to comment Share on other sites More sharing options...
Buggy Nate Posted December 6, 2021 Share Posted December 6, 2021 Yep normal contact adhesive works brilliantly and doesn’t harden the gasket like superglue does. I normally clean the cam cover and glue the gasket in before I do the valves and by the time you are done it is ready to go. 1 1 Link to comment Share on other sites More sharing options...
kilo3 Posted December 6, 2021 Share Posted December 6, 2021 Yamabond, shit is straight magic. Overkill for this application but still. 1 Link to comment Share on other sites More sharing options...
pilninggas Posted December 6, 2021 Share Posted December 6, 2021 i run a bead of clear bathroom silicone sealant in the channel on the cover, stick the gasket in and leave to cure whilst i do the valve job. Link to comment Share on other sites More sharing options...
bwringer Posted December 6, 2021 Share Posted December 6, 2021 I usually use a few strategic thin smears of Threebond 1184 case sealer. Not enough to affect the fit, but enough to keep the gasket stuck to the cover for a bit. You don't need to make a mess and more work in the future by covering the whole channel or anything; just use a few thin dabs in a few corners. I've also used a few dabs of tacky grease in similar situations. 2 1 Link to comment Share on other sites More sharing options...
skipperT Posted December 6, 2021 Share Posted December 6, 2021 Other products to try if you have access to them: gasgacinch and I’ve also had luck with a small amt of grip glue if you need it to set fast. the key is to make sure ALL the oil is off of the surface. And be sure that the thicker areas of the gasket are pressed into the recess (some have this, can’t remember if CP3 cover does…) -Skip Link to comment Share on other sites More sharing options...
Premium Member keithu Posted December 6, 2021 Author Premium Member Share Posted December 6, 2021 Awesome tips, thanks everyone. Weird that I've never run into this before, but I think every other time I've installed a valve cover I either reused the rubber gasket that was still stuck to the cover, or it was a paper gasket with some gasket sealant. 1 Link to comment Share on other sites More sharing options...
