Rdecae81 Posted January 2, 2022 Share Posted January 2, 2022 (edited) so I have removed the front windshield, and I have removed the left side OEM receptacle. Need to install a powerlet female receptacle the powerlet is WAY smaller in diameter, what has anyone used as a filler? also I want to use the OEM connetor, but do not want to cut the original oem wire from the oem receptacle anyone have the part number for the required receptacle for all three items behind the windshield. in this picture 99 100 101 102 it appears 99 & 100 maybe identical. cannot tell if 101 & 102 are identical. Edited January 2, 2022 by Rdecae81 Link to comment Share on other sites More sharing options...
Supporting Member Heli ATP Posted January 2, 2022 Supporting Member Share Posted January 2, 2022 (edited) Search this site for a thread on 'Auxiliary DC Connector?' Then do a search on ebay for 'yamaha dc power outlet connector' or click here... Cycle Terminal Edited January 2, 2022 by Heli ATP Link to comment Share on other sites More sharing options...
Grumpy Goat Posted January 2, 2022 Share Posted January 2, 2022 2 hours ago, Rdecae81 said: also I want to use the OEM connetor, but do not want to cut the original oem wire from the oem receptacle anyone have the part number for the required receptacle for all three items behind the windshield. I have a video on my YT channel that has all the information you are looking for and the part is linked in the Description of the video. Regards, Grumpy Goat | 2019 Yamaha Tracer 900 GT & 2016 BMW R1200RS Link to comment Share on other sites More sharing options...
Rdecae81 Posted January 3, 2022 Author Share Posted January 3, 2022 actually, I went to your YouTube channel to see if something was there, and I did not see a video covering this. link ? Link to comment Share on other sites More sharing options...
Grumpy Goat Posted January 3, 2022 Share Posted January 3, 2022 1 minute ago, Rdecae81 said: actually, I went to your YouTube channel to see if something was there, and I did not see a video covering this. link ? Here you go: https://youtu.be/bw7Z31Fvk34 Regards, Grumpy Goat | 2019 Yamaha Tracer 900 GT & 2016 BMW R1200RS Link to comment Share on other sites More sharing options...
Rdecae81 Posted January 3, 2022 Author Share Posted January 3, 2022 thanks, so I watched the video twice, and looked at all the comments. I admit I am not a youtube user. so , where is the link to the part you purchased? or the part number? I was expecting a link or part number in the comments section or maybe at the end of the video. sorry I am probably missing something, but I did watch it twice. and Yes for the two grey connectors your item is exactly what I am looking for. Still need a connector for the black plug, but if I can get the link to what you purchased that solves 50% of my problem. thank you Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted January 3, 2022 Supporting Member Share Posted January 3, 2022 24 minutes ago, Rdecae81 said: thanks, so I watched the video twice, and looked at all the comments. I admit I am not a youtube user. so , where is the link to the part you purchased? or the part number? I was expecting a link or part number in the comments section or maybe at the end of the video. sorry I am probably missing something, but I did watch it twice. and Yes for the two grey connectors your item is exactly what I am looking for. Still need a connector for the black plug, but if I can get the link to what you purchased that solves 50% of my problem. thank you He put everything in the description located right below the video. LINKS Mounting Hardware ----------------- RAM Mounts Handlebar U-Bolt Base for Rails 0.5" to 1.25" in Diameter RAM-B-231ZU ($17.49) : https://tinyurl.com/pjrvnsrk RAM Mounts RAP-B-201U-A Composite Double Socket Arm - Short Arm Compatible ($9.49) : https://tinyurl.com/8ndsepzx ARKON 25mm Ball to 17mm Ball Adapter - Black - SP25MM17 ($5.95) : https://tinyurl.com/ham3ppck Garmin Automotive suction cup mount ($46.02) : https://tinyurl.com/dd28bns3 Wiring and Connectors needed ---------------------------- EDO Tech Direct 12V Hardwire Car Mount Charger Cable Adapter Kit ($7.00) : https://tinyurl.com/2xdtb9bj New Accessory Power Lead Kit For Yamaha Wolverine RMAX & 850 X2 X4 RMAX2 RMAX4 ($17.29) : https://www.ebay.com/itm/203507679385 Other ----- Rain Weather Cover/Cap for Garmin Zumo 660 665 BMW Navigator IV RoadTech Cradle ($34.99) : https://www.ebay.com/itm/254539866683 Garmin Zumo XT ($500) : https://buy.garmin.com/en-US/US/p/679804 All links are provided for the convenience of viewers. None are affiliate links, and consequently I receive no remuneration from use of these links. GENERAL DISCLAIMER All content and opinions offered on this Channel are my own. Where products are reviewed, they would have been purchased my me for my own use, unless stated otherwise. I have not been sent any products in exchange for reviews, favourable or otherwise. 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted January 3, 2022 Supporting Member Share Posted January 3, 2022 3 hours ago, Rdecae81 said: I admit I am not a youtube user. so , where is the link to the part you purchased? sorry I am probably missing something, but I did watch it twice. Just for your future reference - this is probably what you were missing.. click on the SHOW MORE option and all will be revealed. Link to comment Share on other sites More sharing options...
Rdecae81 Posted January 3, 2022 Author Share Posted January 3, 2022 (edited) thanks for the detail information and the instructions on show more I just went to your link and did the show more and sure enough there it was. 🙂 Edited January 3, 2022 by Rdecae81 Link to comment Share on other sites More sharing options...
Grumpy Goat Posted January 3, 2022 Share Posted January 3, 2022 Thanks to all who assisted Rdecae81 with the YT navigation ... saved me from doing it. 🙂 Rdecae81 - Looks like you are good to go. Good luck with the DIY installation. Now that you know a bit more about YT, check out the other videos on my channel ... there may be others that you might find useful as you work on your Tracer 900 GT. Also don't forget to hit the "Like" and consider subscribing as it helps out the channel and encourages me to make more content. Regards, Grumpy Goat | 2019 Yamaha Tracer 900 GT & 2016 BMW R1200RS Link to comment Share on other sites More sharing options...
Rdecae81 Posted January 3, 2022 Author Share Posted January 3, 2022 (edited) already did both, thanks, and for those wondering per this picture this is for items 99 & 100 https://www.ebay.com/itm/203507679385 so far I have only found this for items 101 & 102, 2SC-8254B-00-00 https://www.ronayers.com/oemparts/a/yam/5b27c67587a8661118ea0061/electrical-1 see part number 30. It is OEM yamaha, but includes the cigarette lighter as well and runs 40.00. obviously, you can cut the wires at the cigarette lighter and have a "pigtail" to use for powering other items. Still trying to find a connector similar to what was found for 99 & 100. No luck so far. But as of now, I really do not need one. Overall I have chosen a different route I am using 99 to run a "trigger" wire to my PDM-60. this fuze panel has both triggered and always on options. so I will then run wires from the PDM-60 as follows Powerlet on left side panel in the wire mesh area (basically to run a mini air compressor or other emergency item) Powerlet on Left side front panel (replaced OEM cigarette lighter) USB/Volt meter on Right side (using the empty OEM bracket) Power to my Phone holder (has wireless charge capability) Power to Gerbing plug (Left side) Power to LED (probably denali R1) running lights In this way I will not be using the OEM connectors/wiring harness in any way (other than the trigger to PDM-60) I have created a wiring loom, with all the wires color coded Black = all ground wires yellow = trigger wire Green = left side panel powerlet (15 amp) Purple = LED running lights (7.5 amps) Blue = front dash Left PowerLet receptacle (Garmin XT) (5 amp) White = Front Dash Right USB/Volt Meter (5amps) Purple = Phone holder power (5 amps) the gerbing connector has it's own wiring (10amps) I can never use the 15amp powerlet if the Gerbings is being utilized, but otherwise there is no problem running all these powered items. Edited January 3, 2022 by Rdecae81 1 Link to comment Share on other sites More sharing options...
