skipperT Posted September 26, 2017 Share Posted September 26, 2017 It doesn’t matter. I’ve seen engines from the factory with the washer installed either way and no problems with a leak. I’ve always installed flat part of washer to the drain bolt, or picture B against the drainbolt, which would put A against the oil pan. -Skip Link to comment Share on other sites More sharing options...
dbeau Posted September 30, 2017 Share Posted September 30, 2017 Thank you @adjuster for the info and links! Amazon prime for PBL 14610 oil filter: Link Just noticed there is some mis-match of numbers going on here. The OP filter list shows the Purolator 14612 is the compatible FJ-09 filter but you've linked the 14610 part. Not sure if this is an error or if both fit but thought it important to point this out so someone doesn't get the wrong one. I have in fact ordered and used 2 PBL 14612 filters now with success for the record. Link to comment Share on other sites More sharing options...
koth442 Posted September 30, 2017 Share Posted September 30, 2017 Thank you @adjuster for the info and links! Amazon prime for PBL 14610 oil filter: Link Just noticed there is some mis-match of numbers going on here. The OP filter list shows the Purolator 14612 is the compatible FJ-09 filter but you've linked the 14610 part. Not sure if this is an error or if both fit but thought it important to point this out so someone doesn't get the wrong one. I have in fact ordered and used 2 PBL 14612 filters now with success for the record. Thanks for pointing that out. That's very strange, I have a bag of PBL 14612's sitting in my garage. Wonder what changed.... '15 FJ09 Link to comment Share on other sites More sharing options...
dbeau Posted October 1, 2017 Share Posted October 1, 2017 After some research it appears that the only difference between the 14610/14612 is the length. The 14610 is a little longer. - http://motorcycleinfo.calsci.com/FilterXRef.html#5 Link to comment Share on other sites More sharing options...
charlesfj09 Posted January 27, 2018 Share Posted January 27, 2018 Seems like it would have only been polite to mention you copied that from my website. I spent a lot of hours putting that list together. . .Point taken, data deleted to comply. Link to comment Share on other sites More sharing options...
charlesfj09 Posted January 27, 2018 Share Posted January 27, 2018 Seems like it would have only been polite to mention you copied that from my website. I spent a lot of hours putting that list together. . .Point taken, data deleted to comply. Well, whoever made the post or shared it should know that it was very helpful. I just did an oil change and it seemed to go pretty well with the amount of oil that was recommended. Thanks guys. I’m a happy FJ09 rider! Link to comment Share on other sites More sharing options...
Premium Member fddriver2 Posted January 28, 2018 Premium Member Share Posted January 28, 2018 What? If anything is the point of the 3 year old whine about open information on the net? I really don't get it. However the weather is nice here in SOFLA it is a bit windy though. 1 "It doesn't matter who walks in, you know the joke is still the same" Ft. Lauderdale, Florida. USA Link to comment Share on other sites More sharing options...
Premium Member DavidS Posted January 28, 2018 Premium Member Share Posted January 28, 2018 It doesn’t matter. I’ve seen engines from the factory with the washer installed either way and no problems with a leak. I’ve always installed flat part of washer to the drain bolt, or picture B against the drainbolt, which would put A against the oil pan. -Skip Makes me feel better to put the round side against the crank case, but I know it really doesn't make any difference! Link to comment Share on other sites More sharing options...
dundee Posted February 7, 2019 Share Posted February 7, 2019 (edited) Not sure why someone would use an automotive oil filter on their Tracer as the OEM filter (5GH-13440-50-00, now 5GH-13440-60-00) is available online for 10-12 USD and sometimes cheaper at Yamaha boat shops (this filter is also used for many Yamaha boat engines). The Wix 51358 (also available from NAPA as NAPA Gold 1358 ) is also specified directly for the Yamaha FJ-09 / MT09 and is a well made motorcycle filter (NAPA has them on sale every 3 months for less than 6 bucks). There is not a lot of clearance between the pipes and the end of the filter with the tiny factory filter, so the discussion about using a longer filter sounds like it would create a lot of fun when changing the filter. No need to make changing your filter a science project. Edited February 7, 2019 by dundee Link to comment Share on other sites More sharing options...
Kevin kelly Posted June 11, 2019 Share Posted June 11, 2019 On 2/28/2015 at 9:40 AM, ULEWZ said: Sorry you had that issue with the fram. I don't use them for other reasons, but that is good enough reason. I like your idea of taking the spare stud to the store and trying different filters. Let us know if you come up with a new one to try. I am currently using the Mobil 1 M1-108 with no issues. You need the "A" on the end of 6018..that is the course thread that is REQUIRED..frame is a poor filter anyway. Link to comment Share on other sites More sharing options...
tryingtobebest Posted May 23, 2021 Share Posted May 23, 2021 Which WIX one does people use, the specs pretty much the same except 51358 does 8-10gpm (galons per minute) rate and 51365 does 9-11gpm also 51365 is filter for automatic transmission and roughly cost few dollars less! Link to comment Share on other sites More sharing options...
kmh0 Posted May 23, 2021 Share Posted May 23, 2021 Great list thank you! Link to comment Share on other sites More sharing options...
kirgudu Posted February 14, 2022 Share Posted February 14, 2022 (edited) Mahle/Knecht Filter OC 574 MANN-FILTER MW 65 Edited February 14, 2022 by kirgudu Link to comment Share on other sites More sharing options...
Cogswell Posted March 16, 2022 Share Posted March 16, 2022 I found Rocky Mountain ATV carries OEM parts now. They sell the Yamaha factory filter for about $9 and change. They are a good source for tires as well. Link to comment Share on other sites More sharing options...
Suzukiguy Posted March 16, 2022 Share Posted March 16, 2022 Cogswell, In case you did not know. Rocky Mountain ATV has a warehouse and store in Winchester, KY that you can go and pick up parts if they are in stock. (Saves shipping costs also.) Has saved my bacon more than once! Just be sure to call their 800 number to place your order and verify that the part is in Winchester and not Utah! 1 2020 Tracer 900GT /1978 Suzuki GS750E /1978 Suzuki GS1000 /1982 Suzuki GS1100E /1999 Honda GL1500SE Link to comment Share on other sites More sharing options...
