Supporting Member betoney Posted April 29, 2022 Supporting Member Share Posted April 29, 2022 I have a stripped bolt on the red body panel of my VFR, it has a blind fastener built into the panel behind it which is spinning in place and completely inaccessible from behind. Do any mechanically minded forum members have any ideas how to remove a bolt that just spins in place without destroying the body panel? The red shroud and black panel behind it that the retainer nut is mounted in are about $300 each. 😲 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Cogswell Posted April 29, 2022 Share Posted April 29, 2022 You could drill the head off of it leaving the rest behind. You would be able to remove the panel at that point. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted April 29, 2022 Author Supporting Member Share Posted April 29, 2022 6 minutes ago, Cogswell said: You could drill the head off of it leaving the rest behind. You would be able to remove the panel at that point. I might give that a try. Thank you! 🍻 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
kilo3 Posted April 29, 2022 Share Posted April 29, 2022 12 minutes ago, betoney said: I might give that a try. Thank you! 🍻 Might be tough if it's spinning, helps if you can apply a little pressure to the panel at the same time as well to kinda hold it in place. Link to comment Share on other sites More sharing options...
BBB Posted April 29, 2022 Share Posted April 29, 2022 How about a blob of araldite on the end of an allen key (presuming it’s an allen head bolt), push it into the bolt so that when it sets you can pull outwards on the screw. That may put enough friction on the hidden fastener to stop it rotating. You can then buy a new bolt if it comes out. Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
Supporting Member Heli ATP Posted April 29, 2022 Supporting Member Share Posted April 29, 2022 If drilling out maybe use a left hand drill so you don't tighten it down? Link to comment Share on other sites More sharing options...
TomTracer Posted April 29, 2022 Share Posted April 29, 2022 (edited) Might try some lift to the screw head while turning it out. Might be able to keep the nut from turning at the same time. Has worked for me in the past. > have used dental floss or fishing line to loop around the fastener head, pull up while turning. Edited April 29, 2022 by TomTracer Added onfo Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted April 29, 2022 Author Supporting Member Share Posted April 29, 2022 1 hour ago, Cogswell said: You could drill the head off of it leaving the rest behind. You would be able to remove the panel at that point. Drilling the head off was the answer, worked like a charm. Thank you for the help. 👍🏻 2 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
peteinpa Posted April 29, 2022 Share Posted April 29, 2022 Got to pick up some left drill bits. Link to comment Share on other sites More sharing options...
Supporting Member Heli ATP Posted April 29, 2022 Supporting Member Share Posted April 29, 2022 35 minutes ago, peteinpa said: Got to pick up some left drill bits. ?meht htiw od uoy dluow tahW 😁 Link to comment Share on other sites More sharing options...
peteinpa Posted April 30, 2022 Share Posted April 30, 2022 🤣 Link to comment Share on other sites More sharing options...
Buggy Nate Posted May 4, 2022 Share Posted May 4, 2022 On 4/30/2022 at 9:49 AM, Heli ATP said: ?meht htiw od uoy dluow tahW 😁 Thought I was having a f’ing stroke. Thanks for that! 🤣🤣🤣 1 Link to comment Share on other sites More sharing options...
