Magnum099 Posted May 13 Share Posted May 13 Over the past couple of weeks, I have noticed my clutch feeling "off" and I could not seem to get it right no matter what adjustments I made on either the engine side or the handlebar side. Also tried lubing it, but to no avail. It seemed like it was getting harder and harder to engage the clutch. After reading about the clutch cable issues on 2015 FJ-09s, I decided it would be best to go ahead and order the updated cable Yamaha released just in case. So I stopped by my local dealer on the way home and ordered it. Low and behold, as I pulled onto the road I live on, the clutch cable snapped when I was changing gears. It broke right at the place where they redesigned the new cable, near the lever. Luckily, I was able to easily ride it home since I was so close. Timing is everything! I got lucky on this one, it could have happened at a much worse time. 8 Link to comment Share on other sites More sharing options...
Supporting Member knyte Posted May 13 Supporting Member Share Posted May 13 Yikes, that is perfect timing. 2015 FJ-09 / touring bags / oil plug mod / Evotech rad guard / SW Motech bash plate / VStream touring windshield / Seat Concepts: Sport Touring / Vcyclenut ABS rings (speedo correction) / Cosmo RAM mount Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted May 13 Premium Member Share Posted May 13 Availability? https://www.partshark.com/oemparts/p/yamaha/2pp-26335-02-00/cable-clutch I'll have to check when I replaced my original, which was not even frayed with a V2, so I know how many miles are on it. I keep it and the throttle cables well lubed along with the throttle tube. I have a spare V2 and am considered keeping it in my top case. That is whenever I get BITS. Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted May 13 Premium Member Share Posted May 13 BITS = Back In The Saddle I should copyright it! Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted May 13 Premium Member Share Posted May 13 Bought my 15 Fastest Red new in 07-16 and now have about 52k miles on the honey. So WOW! So far I've been able to perform all my own work, other than mandatory recalls, including valve lash adjustment and changing tires. Out of my maintenance log 2017/01/21 9,855 Clutch Cable replacement Link to comment Share on other sites More sharing options...
