Dbdb Posted June 8, 2022 Author Share Posted June 8, 2022 53 minutes ago, Buggy Nate said: If you are handy with a relay you can always wire it in so the headlight turns off with a press of a starter button so it still functions the same as stock too. A simple changeover relay will do the trick. Hi @Buggy Nate, I know enough about relays to be dangerous (hence this thread), but it would be useful to have it effectively behave as stock. Ideally I could leave it switched on, but have it triggered with starter. In the short term I'll make do with a switch so I can get it back on the road, not that the weather at the moment makes me want to ride. Link to comment Share on other sites More sharing options...
Dbdb Posted June 15, 2022 Author Share Posted June 15, 2022 I finally got the chance to wire in a switch, apart from being a pain in the arse it was pretty straight forward. Importantly it also works, in the shed anyway. I'm not wrapt in the switch, but it was the best i could find available in a reasonable time frame. 2 1 1 Link to comment Share on other sites More sharing options...
