howie333 Posted May 18, 2022 Share Posted May 18, 2022 (edited) I recently did a Andreani fork Cartridge and Nitron shock exchange. the shock was easy to set spring preload. The forks presently minimum comp/rebound damping to test. The shock w/ reservoir comp/rebound is set from Nitron for my riding style and weight. I left them there cause it feels right so far. I set the front and rear preloads for 30% total suspension travel which comes to 41mm front and 39mm rear sag. There are only 4 turns or rebound and compression damping. Tech @Fast Bike Industries told me to reduce torques of triple tree bolts from spec., to soften fork action from excessive clamping and it's done often; but never heard of that. I'm not sure if that's safe or by what # to retorque ? Any advise; TNX... Edited May 26, 2022 by howie333 Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted May 18, 2022 Premium Member Share Posted May 18, 2022 Reduce fork fluid level and/or go to 16cst @ 40C viscosity (not all, for example, 5w fluid is the same); you must go by cst. Also, 35 mm rear and 25 mm front sag (set based on proper technique) after 45 mph "panic" brake test should be the target. http://mahonkin.com/~milktree/motorcycle/fork-oil.html https://transmoto.com.au/Comparative-Oil-Weights-Table/ https://www.peterverdone.com/archive/files/suspension oils.pdf mix thy own... https://www.widman.biz/English/Calculators/Mixtures.html or try this 5w https://www.ebay.com/itm/231115711119?chn=ps&_trkparms=ispr%3D1&amdata=enc%3A1ky2Nhj02QBuCwkrNdtPTkw14&norover=1&mkevt=1&mkrid=711-213727-13078-0&mkcid=2&itemid=231115711119&targetid=4580702890871448&device=c&mktype=&googleloc=&poi=&campaignid=418640321&mkgroupid=1233652283797640&rlsatarget=pla-4580702890871448&abcId=9300602&merchantid=51291&msclkid=61d8dab1bc691713e82cbb1cc51d50c1 https://cdn.shopify.com/s/files/1/0058/8110/2447/files/RFF.pdf Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted May 19, 2022 Supporting Member Share Posted May 19, 2022 I torque the top and bottom triple clamp bolts to spec, most importantly after installing the wheel is getting the fork legs true on the axle so they don’t bind. instal the axle and tighten, then with the bike on the ground, press down on the forks several times so they settle in their neutral position side to side on the axle and then lastly tighten the axle pinch bolt. 2 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted May 19, 2022 Supporting Member Share Posted May 19, 2022 2 hours ago, howie333 said: The forks presently minimum comp/rebound damping to test. The shock w/ reservoir comp/rebound is set from Nitron for my riding style and weight. I left them there cause it feels right so far. I think you are going to find the test ride with zero damping to be a waste of time, you will effectively be riding the spring, bouncy and wallowy, not what you want for precise control in a corner. You can start testing how you want but just a suggestion; start with more damping and open if needed. I always start setting the damping at full closed and open them 1/3 for the first test and then open or close them a little from there. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
howie333 Posted May 19, 2022 Author Share Posted May 19, 2022 (edited) 17 hours ago, 2and3cylinders said: Reduce fork fluid level and/or go to 16cst @ 40C viscosity (not all, for example, 5w fluid is the same); you must go by cst. Also, 35 mm rear and 25 mm front sag (set based on proper technique) after 45 mph "panic" brake test should be the target. http://mahonkin.com/~milktree/motorcycle/fork-oil.html https://transmoto.com.au/Comparative-Oil-Weights-Table/ https://www.peterverdone.com/archive/files/suspension oils.pdf mix thy own... https://www.widman.biz/English/Calculators/Mixtures.html or try this 5w https://www.ebay.com/itm/231115711119?chn=ps&_trkparms=ispr%3D1&amdata=enc%3A1ky2Nhj02QBuCwkrNdtPTkw14&norover=1&mkevt=1&mkrid=711-213727-13078-0&mkcid=2&itemid=231115711119&targetid=4580702890871448&device=c&mktype=&googleloc=&poi=&campaignid=418640321&mkgroupid=1233652283797640&rlsatarget=pla-4580702890871448&abcId=9300602&merchantid=51291&msclkid=61d8dab1bc691713e82cbb1cc51d50c1 https://cdn.shopify.com/s/files/1/0058/8110/2447/files/RFF.pdf Fast Bike informed me They were out of the Ohlins fluid they usually use, but the Maxima 85-150 5W fork fluid was a CST @40c matchup, and air gap of 120mm. TNX for reply... Edited May 19, 2022 by howie333 Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted May 19, 2022 Premium Member Share Posted May 19, 2022 15 hours ago, howie333 said: Fast Bike informed me They were out of the Ohlins fluid they usually use, but the Maxima 85-150 5W fork fluid was a CST @40c matchup, and air gap of 120mm. TNX for reply... What cst?😁 Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted May 19, 2022 Premium Member Share Posted May 19, 2022 18 hours ago, betoney said: I torque the top and bottom triple clamp bolts to spec, most importantly after installing the wheel is getting the fork legs true on the axle so they don’t bind. instal the axle and tighten, then with the bike on the ground, press down on the forks several times so they settle in their neutral position side to side on the axle and then lastly tighten the axle pinch bolt. I add fine tuning as a last step before tightening the pinch bolt With it up on a steering stem lift stand Spin the front tire forward as fast as you can and then quickly clamp on the front brake lever This shocks the forks into alignment with the rotors I try to get a good fast rotation if the brake pads aren't rubbing too bad and then snap pull the lever Boom x3 Then cinch up the pinch bolt on the stand 1 Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted May 19, 2022 Supporting Member Share Posted May 19, 2022 (edited) On 5/18/2022 at 7:27 PM, howie333 said: Tech @Fast Bike Industries told me to reduce torques of triple tree bolts from spec., to soften fork action from excessive clamping and it's done often; but never heard of that. I'm not sure if that's safe or by what # to retorque ? This sounds like maybe something meant as an in-shop/garage type of check to see if fork tubes aren't binding in the clamps, not for you to loosen the clamps and go riding. Strange advice IMO. Check that the outer tubes are perfectly straight/aligned through the upped and lower clamps. Torque to spec. Let the fork (one that's floating on axle) align true and then tighten the pinch bolt. Edited May 20, 2022 by piotrek Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted May 19, 2022 Supporting Member Share Posted May 19, 2022 3 hours ago, 2and3cylinders said: This shocks the forks into alignment with the rotors The forks should be aligned true on the axle, unimpeded by the brakes. Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted May 20, 2022 Premium Member Share Posted May 20, 2022 3 hours ago, piotrek said: The forks should be aligned true on the axle, unimpeded by the brakes. In my experience, if the rotors are not warped, my fine tuning procedure ensures the forks are coincident with the wheel and de facto the axle; given the wheel bearings are also true. Link to comment Share on other sites More sharing options...
sandman900 Posted March 2 Share Posted March 2 On 5/19/2022 at 9:06 PM, 2and3cylinders said: In my experience, if the rotors are not warped, my fine tuning procedure ensures the forks are coincident with the wheel and de facto the axle; given the wheel bearings are also true. Question- do you have any recommendations for fork service in the Chicago/midwest area? I just want to replace my fork springs/oil on my stock 5K mile 2020 Tracer- probably Racetech springs. I've had good luck with Trackside Engineering in WI on a previous bike's Ohlins shock. Any shop closer that's good? https://tracksidesuspension.com/services/ Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted March 2 Premium Member Share Posted March 2 I've used Trackside too but only for shock refreshes. Springs are easy with some inexpensive tools. Dump, flush with ATF a couple times, add 16Cst fluid to 155 mm, add a couple of .035 washers on the OEM spacers with say .95 kg springs and away you go. No suspension experts but Stan at https://motoandmotor.com/ Kind of a jerk and has gotten pricey in Northbrook. Heard good things about https://www.midwestperformancetuning.com/ I do my own work, sorry Link to comment Share on other sites More sharing options...
