petshark Posted July 18, 2022 Share Posted July 18, 2022 On 6/29/2022 at 1:54 AM, MightBeSasquatch said: The 21' has it listed at 77 foot pounds, so that's a plus. I am still unsure if I am happy with their updated chain slack spec. The 21 has bigger axles and nuts. When shopping for a tyre machine I noticed that pre-21 have smaller axles than almost any other bike. So much so that you have to buy extra adapters or you can not use the machine. Could it be that Yamaha engineers want more torque on undersized parts. Link to comment Share on other sites More sharing options...
robzilla Posted March 27, 2023 Share Posted March 27, 2023 I have some upcoming spring maintenance & mods including the chain slack, so I appreciate the earlier comments including the 77 ft/lbs. What's the axle nut size for the '21-22? I remember reading 32mm- same as earlier models? Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted March 27, 2023 Premium Member Share Posted March 27, 2023 15~20 axle nut was 27 mm, tq 108 & slack 15 mm. I went with the LighTech Chicom clone adjusters* (1/4 the $ & still work well after 5 years), tq to 82 "# with 1.375" slack. I adjust slack on the left and align with the right checking with a MP sprocket clamp / rod tool (with a replacement rod I cut double+ length)*** & a vernier caliper, and then pretension using a MP sprocket jamb tool^ and a much less expensive clone of the Chain Monkey chain tensioner** (a screwdriver & rag is a so-so substitute) . *https://www.lightechuk.com/lightech-yamaha-mt-09-13---16--mt09-tracer--xsr900-13---20-chain-adjuster-kit-11868-p.asp **https://www.amazon.com/motorcycle-monkey-tension-setting-tru-tension/dp/b015yd9wjw ***https://www.amazon.com/dp/B094D3M28L/ref=sspa_dk_detail_0?psc=1&pd_rd_i=B094D3M28L&pd_rd_w=BFM1y&content-id=amzn1.sym.88097cb9-5064-44ef-891b-abfacbc1c44b&pf_rd_p=88097cb9-5064-44ef-891b-abfacbc1c44b&pf_rd_r=XT2FA2J08N3BQQMW97TR&pd_rd_wg=FMmyF&pd_rd_r=d6d41487-ec05-41d8-a389-021c6d921bd2&s=automotive&sp_csd=d2lkZ2V0TmFtZT1zcF9kZXRhaWw&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExTUpVMTcxTDFYR0M2JmVuY3J5cHRlZElkPUEwODA0MTkzMTVEQVIwN1FMUjRUNCZlbmNyeXB0ZWRBZElkPUEwNzc3NDY0MVpCWVI3R0NRUjlINyZ3aWRnZXROYW1lPXNwX2RldGFpbCZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU= https://www.amazon.com/Motion-Pro-Sprocket-Jammer-08-0642/dp/B06XHPFX56/ref=sr_1_18?crid=S4MJH36DQIIR&keywords=motion+pro+chain+adjuster+jamb+tool&qid=1679942685&s=automotive&sprefix=motion+pro+chain+adjuster+jamb+tool%2Cautomotive%2C174&sr=1-18 ^https://www.amazon.com/Motion-Pro-Sprocket-Jammer-08-0642/dp/B06XHPFX56/ref=sr_1_18?crid=S4MJH36DQIIR&keywords=motion+pro+chain+adjuster+jamb+tool&qid=1679942685&s=automotive&sprefix=motion+pro+chain+adjuster+jamb+tool%2Cautomotive%2C174&sr=1-18 1 Link to comment Share on other sites More sharing options...
OldBikers Posted March 28, 2023 Share Posted March 28, 2023 From 2021 to present it is a 32mm. 1 Link to comment Share on other sites More sharing options...
