Ferrett847 Posted August 26, 2022 Share Posted August 26, 2022 Evening all I've ment to ask this question ages ago ,do any of you notice your screens wobble from side to side a lot .I have the puig touring screen fitted and I've really noticed it shakes a lot .I can't seem to find a reason for it .I've just fitted new tyres wheels balanced professionally and it actually appears worse on the new rubber .There's a no real vibes coming through the bars etc . Link to comment Share on other sites More sharing options...
KrustyKush Posted August 26, 2022 Share Posted August 26, 2022 Have you checked all the fasteners that hold the windscreen bracket onto the bike? Sounds like something is loose. My 21 GT doesn't wiggle side to side at all. Link to comment Share on other sites More sharing options...
Ferrett847 Posted August 27, 2022 Author Share Posted August 27, 2022 Everything's secure its very strange ,I may just swap the screen out to see if that makes a difference. Link to comment Share on other sites More sharing options...
rjknupp Posted September 12, 2022 Share Posted September 12, 2022 My Niken was perfect up until the moment new front tires were installed. Wobble ever since. Had the bike to two shops trying to resolve it. Bike is actually in the shop right now trying to stop the Wobble. I've seen multiple people complain about the Wobble and I've not seen anyone resolve it yet. I suspect that the toe-in adjustment may need recalibration. Trying that currently. The long, really long shot is valve stems. In reading the manual, T412 "short" stems are specified. I know the valve stems pass very close to the brake caliper. When my front tires were replaced, the shop installed new long valve stems. I wonder if maybe the long valve stems aren't whiffing by the caliper inducing the wobble. Like I said, it's a long shot. I'll post a fix if I get one. 1 Link to comment Share on other sites More sharing options...
skipperT Posted September 12, 2022 Share Posted September 12, 2022 3 hours ago, rjknupp said: My Niken was perfect up until the moment new front tires were installed. Wobble ever since. Had the bike to two shops trying to resolve it. Bike is actually in the shop right now trying to stop the Wobble. I've seen multiple people complain about the Wobble and I've not seen anyone resolve it yet. I suspect that the toe-in adjustment may need recalibration. Trying that currently. The long, really long shot is valve stems. In reading the manual, T412 "short" stems are specified. I know the valve stems pass very close to the brake caliper. When my front tires were replaced, the shop installed new long valve stems. I wonder if maybe the long valve stems aren't whiffing by the caliper inducing the wobble. Like I said, it's a long shot. I'll post a fix if I get one. Very interesting. I like your valve stem theory a lot, could be the culprit and it’s an easy swap to see if it makes a difference. Did you have the same OEM tires installed?perhaps Yamaha installed those for a reason and they are special for the Niken? Did they somehow swap rims, and put the LH side on the right and vice versa? -Skip Link to comment Share on other sites More sharing options...
Ferrett847 Posted September 12, 2022 Author Share Posted September 12, 2022 The problem was wheel balancing .The wheels was on the correct sides and no not oe tyres but never had the issue before .I installed some dyna balancing beads and it's worked a treat although I was very sceptical at first . 1 Link to comment Share on other sites More sharing options...
