Eduardo Scherer Posted November 25, 2022 Share Posted November 25, 2022 On 10/5/2022 at 4:59 PM, CMG707 said: Just picked up my new 39L top case and in reading through the install instructions, Yamaha has a warning - Do not use a top case if side cases (saddlebags) are also installed ?? I have seen many bikes with both top cases and saddlebags, so is this just a CYA by Yamaha? Any info would help CMG I ride with the Givi trio - the side V37's and the top G47, and riding solo and loaded the front can get a bit light, but nothing to worry about if you keep speed and acceleration in "normal" mode, and do not load excessively the top case. The bike really shifts backwards in the centerstand but I have never had an issue when refuelling it in that configuration, which is standard to me when filling it up. Link to comment Share on other sites More sharing options...
Premium Member 1moreroad Posted November 25, 2022 Premium Member Share Posted November 25, 2022 On 11/24/2022 at 7:01 AM, harraseeket said: How is this different from carrying a 150 lb. pillion which is OK ? Exactly. Given how relatively light the front end of the FJ is, I assumed it was a combined risk of wind resistance and rear weight bias that could cause the front end wobble. But my passenger weighs at least 2x more probably 3x more than any amount of luggage I could fit. Maybe she's more aerodynamic? Link to comment Share on other sites More sharing options...
Premium Member sirepair Posted November 27, 2022 Premium Member Share Posted November 27, 2022 On 11/25/2022 at 9:08 AM, Eduardo Scherer said: Would you share some pictures of the ammo box under the tail instalation? That's sound enticing to me. Thanks! Check here: 1 Link to comment Share on other sites More sharing options...
