reaperxtk Posted October 18, 2022 Share Posted October 18, 2022 hi, i recently bought a tracer 900 2016, the previous owner had the ecu flashed, the bike now have a ton of extra power but every time i start it it always starts on A mode, is there any way to change it to STD? maybe from the DIAG menu? Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted October 18, 2022 Supporting Member Share Posted October 18, 2022 You can change the mode from the right side mode button but would need to do that every time the bike is started. For a permanent change to default to STD at startup would require an ECU flash. … or you could ride it for awhile and get used to the power output. I have mine default to A mode and a smooth throttle input makes for a very smooth ride. 😎👍🏻 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
bwringer Posted March 17, 2023 Share Posted March 17, 2023 "A" mode doesn't magically produce more power; it just makes the throttle response more abrupt. I believe "B" mode does reduce available power and softens power delivery, but "Standard" and "A" mode produce exactly the same peak power, just with different throttle response curves. You can get used to it, I guess, and some people prefer it, but personally, I really, really hate "A" mode. As noted, the only fix for changing the default is a re-flash. If you're otherwise happy with the way it works, it would be best to figure out where the PO got it flashed and ask them; much of the time they'll charge a lot less for just changing a few parameters. 3 Link to comment Share on other sites More sharing options...
