prmurat Posted October 31, 2022 Share Posted October 31, 2022 I finally decided to install some old Vmax, black, mirrors on my GT, ordered the blanking anodized parts for the stock mirrors and some hand guards with turn signals... guards are touching the fairing when turning, so I cannot install them. Any idea for turn signals in place of the stock mirrors?Thks Link to comment Share on other sites More sharing options...
Supporting Member Heli ATP Posted October 31, 2022 Supporting Member Share Posted October 31, 2022 I have these on my Niken and love them... https://kiwavmotors.com/en/parts/controls/mirrors/road-naked/two-tone-led-neat-stem-mirrors-lucifer-black-universal-fit-detail ...and everything they say in the advert is true. Very good quality. I did a write up on the install in the Niken mirror turn signal thread. Link to comment Share on other sites More sharing options...
prmurat Posted November 1, 2022 Author Share Posted November 1, 2022 Thks for your answer. I will keep on looking on how to install turn signals on the stock place(s). Link to comment Share on other sites More sharing options...
Supporting Member Heli ATP Posted November 1, 2022 Supporting Member Share Posted November 1, 2022 I removed the stock mirrors and replaced them with spot led's. You could do the same and install aftermarket turn signals. In the first pic you can see the connectors after the stock mirror/turn signals were unplugged. The second pic shows my home made holder for the spots which would hold turn signals as you prefer. My hand guards are from the 2015-17 FJ-09 with the knuckle guard LED kit available on ebay. Can you share where you got 'the blanking anodized parts for the stock mirrors' and maybe show installed pic? Link to comment Share on other sites More sharing options...
prmurat Posted November 1, 2022 Author Share Posted November 1, 2022 I like your FJ-09 hand guards... do they touch the fairing going full lock to full lock? Mirror block off kit are there: https://www.aliexpress.us/item/2251832866998812.html?spm=a2g0o.productlist.0.0.30e66d0bWjHkaC&algo_pvid=c19a8a2d-e530-4b51-8f67-78e495638059&algo_exp_id=c19a8a2d-e530-4b51-8f67-78e495638059-1&pdp_ext_f={"sku_id"%3A"67478354890"}&pdp_npi=2%40dis!USD!17.49!13.47!!!!!%402101e9d016673193526016474e3469!67478354890!sea&curPageLogUid=14llYiTr6pe0 I have not installed them as I still have to find a solution for the blinkers... If I do get the hand guards I'll try these (or same style) installed on my blue plates: https://www.aliexpress.us/item/3256802767794360.html?spm=a2g0o.productlist.0.0.25ab3df8YH25Ml&algo_pvid=cddeab6a-a0ef-4aec-947e-b7fcce689a36&algo_exp_id=cddeab6a-a0ef-4aec-947e-b7fcce689a36-1&pdp_ext_f={"sku_id"%3A"12000022939862252"}&pdp_npi=2%40dis!USD!29.45!22.09!!!!!%40210318b816673196179248166e9817!12000022939862252!sea&curPageLogUid=O0TB0hMNDmG0 Link to comment Share on other sites More sharing options...
Supporting Member Heli ATP Posted November 1, 2022 Supporting Member Share Posted November 1, 2022 The FJ-09 Hand Guards work fine full left to right. I had to make some adjustments to the original brackets to make them work. I have Pyramid Handguard Extensions for install that will give me more coverage for the next few months with colder temps. I don't see how your blue block off plates will cover the holes for the mirror delete. You can purchase some aluminum plate at Home Depot / Lowes and make some with a hacksaw, file and a drill. Link to comment Share on other sites More sharing options...
