Traveler Thomas Posted December 15, 2022 Share Posted December 15, 2022 I changed out my factory turnsignals to sequential led lights. The kit came with 4 lights and four 10w resistors. I did the front ones first and everything worked fine, after doing the rear lights I got a really weird flashing sequence, the lights would not flash all the way across. Does anybody have any ideas how to resolve this issue? Link to comment Share on other sites More sharing options...
miweber929 Posted December 15, 2022 Share Posted December 15, 2022 (edited) 46 minutes ago, Traveler Thomas said: I changed out my factory turnsignals to sequential led lights. The kit came with 4 lights and four 10w resistors. I did the front ones first and everything worked fine, after doing the rear lights I got a really weird flashing sequence, the lights would not flash all the way across. Does anybody have any ideas how to resolve this issue? Remove the resistors and replace the flasher with an LED capable solid state unit. I think 4 resisters may be too many but it’s hard to tell. Replacing the flasher relay is a guaranteed fix. Edited December 15, 2022 by miweber929 3 Link to comment Share on other sites More sharing options...
RaYzerman Posted December 15, 2022 Share Posted December 15, 2022 To get sequentials to work, you'll have to slow the flash rate down some more. You could try more resistors, however, a proper LED capable flasher might be a necessity. I'd go for that first. 1 Link to comment Share on other sites More sharing options...
Traveler Thomas Posted December 17, 2022 Author Share Posted December 17, 2022 Thank you for the help, I purchased a TST adjustable T/S relay! 1 Link to comment Share on other sites More sharing options...
