Guest spunrdneck Posted May 30, 2015 Share Posted May 30, 2015 nicely done sir! pics always help! Link to comment Share on other sites More sharing options...
Premium Member fj09ismine Posted May 30, 2015 Premium Member Share Posted May 30, 2015 Took my time lining everything up. Automatic center punch. I used a 3/16" drill bit. Nuts secure on the back side, install both screws and spacers at the same time, be gentle and tighten them up. Looking good so far. The spare terminal. I stripped back the wires a bit, combined them and installed them in the connector. Job done. These are great pictures, but any chance you have photos of the flasher sync? Would really be interested in seeing how to tap the three wires coming from the signal. Link to comment Share on other sites More sharing options...
sixcharlie Posted May 30, 2015 Share Posted May 30, 2015 I did not order the kit with the flasher so unfortunately I can't help out there. The instructions end with "and here are the spare terminals" so I wanted to show how I decided to wire them in to help other folks. Was at the dealer earlier, helped them sell and FJ-09 and showed them these LEDs. They are going to order some now. They look GREAT on the bike, IMO. Link to comment Share on other sites More sharing options...
sixcharlie Posted May 30, 2015 Share Posted May 30, 2015 Can you post a picture of the flasher sync and wires? I may be able to figure it out. Link to comment Share on other sites More sharing options...
Premium Member fj09ismine Posted May 30, 2015 Premium Member Share Posted May 30, 2015 Can you post a picture of the flasher sync and wires? I may be able to figure it out. According to my kit, the sync is programmed into the LEDS so there are no additional wires. Here are the instructions Link to comment Share on other sites More sharing options...
mjsracing Posted May 31, 2015 Share Posted May 31, 2015 I think there is a bit of confusion about the turn signal flash function with these LED conspicuity lights. The light assemblies have 2 wires, + and ground. If you desire them to flash with you turn signals, you will need either: a control box (as illustrated in the instructions but NOT included in my kit) homebrew control circuit. The light assemblies do not have the control box built in. Control of the LED's is more complicated than the front turn signals / running lights as they have 3 wires, + for running, + for turn, and ground. When the turn signals are flashing, the power is applied then removed from the + turn lead by the flasher relay. A functional spec for the control box or circuit is as follows: [span] If power on, light the LED [/span][span] When the turn signal power comes on, leave the LED illuminated until the turn signal turns off. [span] Once the turn signal goes off, extinguish the LED. [span] If the power is on, and the turn signal power has not been on for approximately 4 seconds[/span] re-illuminate the LED This is how the halo lights in a lot of cars operate. Should be able to source the control box somewhere. [/span] [/span] 2015 FJ-09, 2016 1290 Super Duke, 2017 150 XC-W (primary ride), 2012 DR650 Link to comment Share on other sites More sharing options...
b12ty Posted June 1, 2015 Share Posted June 1, 2015 I think there is a bit of confusion about the turn signal flash function with these LED conspicuity lights. The light assemblies have 2 wires, + and ground. If you desire them to flash with you turn signals, you will need either: a control box (as illustrated in the instructions but NOT included in my kit) homebrew control circuit. The light assemblies do not have the control box built in. Control of the LED's is more complicated than the front turn signals / running lights as they have 3 wires, + for running, + for turn, and ground. When the turn signals are flashing, the power is applied then removed from the + turn lead by the flasher relay. A functional spec for the control box or circuit is as follows: [span] If power on, light the LED [/span][span] When the turn signal power comes on, leave the LED illuminated until the turn signal turns off. [span] Once the turn signal goes off, extinguish the LED. [span] If the power is on, and the thru signal power has not been on for approximately 4 seconds[/span] re-illuminate the LED This is how the halo lights in a lot of cars operate. Should be able to source the control box somewhere. [/span] [/span] Aha! I figured there had to be some delay or the "on" signal would turn out the knuckleguard light. That's why the video is edited everytime it shows a different mode. I had a electronic flasher on another bike that would delay like that. Ended up putting in resistors instead to slow down the flash rate. Maybe not directly related to this, but was annoying. Not sure i'd like it to skip a cycle, when changing lanes for example. But considering it's not the main signal, and in front, maybe no biggie. I may just use mine wired up as signals only. ( would have to cover them with amber tape. ) Ty '05 Bandit 1200s ( Blue and White ) Bandit pic 2015 FJ-09 ( RED ) FJ-09 pic Link to comment Share on other sites More sharing options...
clementevo Posted July 19, 2015 Share Posted July 19, 2015 anyone has the signal module installed? any advice on where to connect the 3 wires to? Link to comment Share on other sites More sharing options...
mjsracing Posted July 19, 2015 Share Posted July 19, 2015 Connect the three wires to the existing turn signal/running lights: Ground, Running Light power, Turn signal power. The two wires go to the LED: Ground, Power. 2015 FJ-09, 2016 1290 Super Duke, 2017 150 XC-W (primary ride), 2012 DR650 Link to comment Share on other sites More sharing options...
JJM Posted July 30, 2016 Share Posted July 30, 2016 Just received my kit. It came with red washers instead of gold. Bummer. Had to paint them black. Link to comment Share on other sites More sharing options...
Premium Member joeszup Posted July 30, 2016 Premium Member Share Posted July 30, 2016 Dammit... they aren't available any more Link to comment Share on other sites More sharing options...
JJM Posted July 30, 2016 Share Posted July 30, 2016 Dammit... they aren't available any more Amber are available. Search for this item number on eBay: 172204004944 Link to comment Share on other sites More sharing options...
Premium Member joeszup Posted July 30, 2016 Premium Member Share Posted July 30, 2016 Found the white again! http://www.ebay.com/itm/YAMAHA-FJ-09-MT-09-TRACER-Knuckle-guard-LED-Kit-White-/172204027933?var=&hash=item281828f01d:m:mki0q6KZkpolCgcn9DhHK-Q&vxp=mtr Link to comment Share on other sites More sharing options...
Cruizin Posted July 31, 2016 Share Posted July 31, 2016 The elusive white! Yamaha FZ-10 Forum Yamaha FZ-07 Forum Yamaha Ténéré 700 Forum Link to comment Share on other sites More sharing options...
JJM Posted July 31, 2016 Share Posted July 31, 2016 I've decided to wire mine to only be used as turn signals. Not really liking how they look constantly on. Link to comment Share on other sites More sharing options...
