mattemike Posted March 25, 2015 Share Posted March 25, 2015 Installed ASV Shorty levers; work great. I'm going with ASV's also. I like their adjustment wheel rather than lever which typically only moves 5 positions. Shorties for me especially clutch as I've a nerve damaged left arm which can be a challenge. Yamaha lists them in their accessory guide but last week they were back ordered. Link to comment Share on other sites More sharing options...
delnari Posted March 25, 2015 Share Posted March 25, 2015 I have been running the "TheTwoWheels" levers on my last three bikes, Ducati, BMW, and Yamaha FZ-09. They work very well but the colors will bleach in the direct sun over time, but for the price you can get new levers every other year, or go with factory silver color and be done with it. Link to comment Share on other sites More sharing options...
vince Posted May 23, 2015 Share Posted May 23, 2015 Installed ASV Shorty levers; work great. Help! What is the free play till brake light activation? Stock levers have 13mm measured from lever end to bar. Looking to get rid of this slack Link to comment Share on other sites More sharing options...
trench Posted May 23, 2015 Share Posted May 23, 2015 You can contact ASV Inventions directly and get any C/5 length or color for the FJ-09. The are a bit cheaper than buying through Yamaha. http://asvinventions.com/C-5/ Link to comment Share on other sites More sharing options...
praztek Posted February 3, 2016 Share Posted February 3, 2016 I picked up the fp racing levers as seen below due to the Pazzos being on backorder Installed and took to yamaha dealer to check adjustment, free play ,etc They said with it set all the way out to 6 on the dial , and lever pulled all the way up against the grip that it should be in by another inch. Long term this will cause clutch problems, which I don't want on a brand new bike Any advice, probably will just put back on the stock levers https://www.motomummy.com/levers/fp-racing-sport-lever-set/ Link to comment Share on other sites More sharing options...
Premium Member peporter Posted February 3, 2016 Premium Member Share Posted February 3, 2016 I picked up the fp racing levers as seen below due to the Pazzos being on backorder Installed and took to yamaha dealer to check adjustment, free play ,etc They said with it set all the way out to 6 on the dial , and lever pulled all the way up against the grip that it should be in by another inch. Long term this will cause clutch problems, which I don't want on a brand new bike Any advice, probably will just put back on the stock levers https://www.motomummy.com/levers/fp-racing-sport-lever-set/ I've been using these for the past 10 months, and they are just fine. Price is right also. http://www.amazon.com/USL-258-Adjustable-Motorcycle-Clutch-2015-Gold/dp/B00T3WMIQU/ref=sr_1_1?ie=UTF8&qid=1454529393&sr=8-1&keywords=USL-258 Link to comment Share on other sites More sharing options...
checkereddemon Posted February 4, 2016 Share Posted February 4, 2016 The ASV levers have a *lifetime* warranty against breakage, no exclusions whatsoever. Plus they claim universal fit so you could keep them for another bike if you sell yours. Very cool!! -CD- 2015 Yamaha FJ-09: RaceTech Gold Valves, RaceTech Rear Spring, Arrow Full Exhaust - black with w/Carbon Fibre endcap, ECU Flash, Lowered 20mm front, 15 mm rear, Denali driving lights, Fenda Extenda, Tail Tidy, Corbin Seat, Madstad 22" Windshield, OEM heated grips, Woodcraft frame sliders, Grip Puppies, BadAss Cover (Large).... Link to comment Share on other sites More sharing options...
riverfox Posted February 4, 2016 Share Posted February 4, 2016 I picked up the fp racing levers as seen below due to the Pazzos being on backorder Installed and took to yamaha dealer to check adjustment, free play ,etc They said with it set all the way out to 6 on the dial , and lever pulled all the way up against the grip that it should be in by another inch. Long term this will cause clutch problems, which I don't want on a brand new bike Any advice, probably will just put back on the stock levers https://www.motomummy.com/levers/fp-racing-sport-lever-set/ I'm confused? Were they saying that even with the clutch lever pulled in it was still not disengaging fully, or was there a different issue? Link to comment Share on other sites More sharing options...
praztek Posted February 4, 2016 Share Posted February 4, 2016 I picked up the fp racing levers as seen below due to the Pazzos being on backorder Installed and took to yamaha dealer to check adjustment, free play ,etc They said with it set all the way out to 6 on the dial , and lever pulled all the way up against the grip that it should be in by another inch. Long term this will cause clutch problems, which I don't want on a brand new bike Any advice, probably will just put back on the stock levers https://www.motomummy.com/levers/fp-racing-sport-lever-set/ I'm confused? Were they saying that even with the clutch lever pulled in it was still not disengaging fully, or was there a different issue? That's my understanding and being a new bike and extended warranty purchased, stealer ship or not , I'm not mechanical inclined to fix any major issues with clutch internals, if it did ever happen, who knows. Keep in mind only adjustments were made at the lever adjuster dial. Link to comment Share on other sites More sharing options...
riverfox Posted February 5, 2016 Share Posted February 5, 2016 I'm confused? Were they saying that even with the clutch lever pulled in it was still not disengaging fully, or was there a different issue? That's my understanding and being a new bike and extended warranty purchased, stealer ship or not , I'm not mechanical inclined to fix any major issues with clutch internals, if it did ever happen, who knows. Keep in mind only adjustments were made at the lever adjuster dial. I'm finding that really hard to believe. If you adjust actual adjustment wheel at the clutch lever so it has free play after you release the lever then start the bike and pull in the clutch, put it in 1st gear and the bike does not want to creep forward I don't see a problem with the lever. Once it is in gear you should be able to let the clutch lever out a little at a time and you will feel it start to engage just slightly before you reach the end of its travel. Find a fellow rider in the are and they should be able to determine if it is disengaging and engaging correctly. Call F+P and they should be able to give you the info you need to feel comfortable. Sounds like the clutch freeplay was never adjusted correctly. Link to comment Share on other sites More sharing options...
praztek Posted April 13, 2016 Share Posted April 13, 2016 That's my understanding and being a new bike and extended warranty purchased, stealer ship or not , I'm not mechanical inclined to fix any major issues with clutch internals, if it did ever happen, who knows. Keep in mind only adjustments were made at the lever adjuster dial.I'm finding that really hard to believe. If you adjust actual adjustment wheel at the clutch lever so it has free play after you release the lever then start the bike and pull in the clutch, put it in 1st gear and the bike does not want to creep forward I don't see a problem with the lever. Once it is in gear you should be able to let the clutch lever out a little at a time and you will feel it start to engage just slightly before you reach the end of its travel. Find a fellow rider in the are and they should be able to determine if it is disengaging and engaging correctly. Call F+P and they should be able to give you the info you need to feel comfortable. Sounds like the clutch freeplay was never adjusted correctly. Alright back for another round , been riding with oem levers and thought I'd give it another try With th FP levers I don't get anywhere in the ballpark of free play as with the oem levers which was approx 14mm taken per the manual. The cable is very tight , but pulling lever in does stop the bike and no creeping forward Link to comment Share on other sites More sharing options...
madsquabbles Posted April 13, 2016 Share Posted April 13, 2016 On topic (kind of). I used full length ASV levers that I had on my fz09 and they bolted right up to the fj09. No clearance issues or any other problems. Just FYI these were purchased from yamaha for the FZ before the FJ was even out so I can say for sure they work on both bikes. Link to comment Share on other sites More sharing options...
spicymayo Posted April 13, 2016 Share Posted April 13, 2016 I bought these ebay specials, and really like them http://www.ebay.ca/itm/401081264617?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT I had a similar pair on my old bike and had no issues at all. Link to comment Share on other sites More sharing options...
Premium Member foxedupone Posted April 13, 2016 Premium Member Share Posted April 13, 2016 I've been happy with multi adjustable Ebay levers as well. Especially that they come in orange! But my favorite feature is that I like my clutch lever long and my front brake to be a shorty. These cheap levers allowed me to play around and realize that that's the setup I liked the best. Link to comment Share on other sites More sharing options...
praztek Posted April 13, 2016 Share Posted April 13, 2016 Alright back for another round , been riding with oem levers and thought I'd give it another try With th FP levers I don't get anywhere in the ballpark of free play as with the oem levers which was approx 14mm taken per the manual. The cable is very tight , but pulling lever in does stop the bike and no creeping forward Guess my concern is just touching the lever there is already tension on 1 mm of pulling back , where on the stock lever it was approx 14mm before cable tension. Link to comment Share on other sites More sharing options...
