caribou Posted June 4, 2015 Share Posted June 4, 2015 Had my rear tyre changed today at local garage and during my 20 min drive home I noticed ABS light was constantly on. Rear brake is also very weak and starts gripping only when I fully compress pedal. What could be the cause of this? Link to comment Share on other sites More sharing options...
GoldenPenguin Posted June 4, 2015 Share Posted June 4, 2015 check that the sensor was put back on appropriately and they didn't break anything in the process. is the light flashing, or just solid on? Link to comment Share on other sites More sharing options...
skipperT Posted June 4, 2015 Share Posted June 4, 2015 Had my rear tyre changed today at local garage and during my 20 min drive home I noticed ABS light was constantly on. Rear brake is also very weak and starts gripping only when I fully compress pedal. What could be the cause of this? Sounds to me like the rear tire wasn't put back on correctly. Sorry man, but you'll need to go visit the shop again and have 'em do the job correctly. Skip Link to comment Share on other sites More sharing options...
mjsracing Posted June 4, 2015 Share Posted June 4, 2015 Is the brake fluid between the lines on the reservoir ? Was the pedal height adjusted? Have you tried bleeding? Take it back to the mechanic if you feel they are competent. 2015 FJ-09, 2016 1290 Super Duke, 2017 150 XC-W (primary ride), 2012 DR650 Link to comment Share on other sites More sharing options...
Premium Member peporter Posted June 6, 2015 Premium Member Share Posted June 6, 2015 Had my rear tyre changed today at local garage and during my 20 min drive home I noticed ABS light was constantly on. Rear brake is also very weak and starts gripping only when I fully compress pedal. What could be the cause of this? Sounds to me like the rear tire wasn't put back on correctly. Sorry man, but you'll need to go visit the shop again and have 'em do the job correctly. Skip The service manual goes to great lengths to stress care when handling the ABS sensors on the wheels, especially dropping them. Sounds like that might have happened. Keep us posted on what your dealer says please. Link to comment Share on other sites More sharing options...
praztek Posted February 9, 2016 Share Posted February 9, 2016 Kind of late , and the resolution was ? Link to comment Share on other sites More sharing options...
