guernsey70 Posted June 4, 2015 Share Posted June 4, 2015 .......is this normal for the gearbox to be so stiff on the FJ 09? Thanks G70 Link to comment Share on other sites More sharing options...
Premium Member wessie Posted June 4, 2015 Premium Member Share Posted June 4, 2015 No On my Super Tenere, the gear shift got very notchy. Some gunge had got into the pivot joint on the gear shifter. It is a simple job to disassemble and grease the joint. This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
Guest rszk Posted June 5, 2015 Share Posted June 5, 2015 If the bike is brand new, it will get better. I noticed mine improve and now that I have 2000km, it's very nice. Link to comment Share on other sites More sharing options...
fullclip Posted June 5, 2015 Share Posted June 5, 2015 Check your chain tension? Mine was so tight that the bike was under heavy tension right from the point of delivery and my dealer said yamaha Manuel states a minimal amount of play in the chain but I say bull crap because it causes wear on sprockets and the chain !! I loosened mine up as soon as I got it home and shifting improved greatly and the bike was coasting freely with no stress if you get my drift Link to comment Share on other sites More sharing options...
b12ty Posted June 6, 2015 Share Posted June 6, 2015 Check your chain tension? Mine was so tight that the bike was under heavy tension right from the point of delivery and my dealer said yamaha Manuel states a minimal amount of play in the chain but I say bull crap because it causes wear on sprockets and the chain !! I loosened mine up as soon as I got it home and shifting improved greatly and the bike was coasting freely with no stress if you get my driftNot to mention wear on the countershaft's bearing. I did the same as soon as I got mine home. Drum tight...ack! Ty '05 Bandit 1200s ( Blue and White ) Bandit pic 2015 FJ-09 ( RED ) FJ-09 pic Link to comment Share on other sites More sharing options...
guernsey70 Posted June 6, 2015 Author Share Posted June 6, 2015 I will check the grease on the gear shifter, but how much do you recommend I loosen the chain by? Link to comment Share on other sites More sharing options...
fullclip Posted June 6, 2015 Share Posted June 6, 2015 I put mine the center stand then made the adjustment to about 1 and 1/4 inches then took it for a ride. Then loosened it to a solid 1 1/4" of play. Remember when you sit on the bike all that play gets taken up. Link to comment Share on other sites More sharing options...
fullclip Posted June 6, 2015 Share Posted June 6, 2015 I don't think lube on shift post is going to play a huge part here? I would not want it bone dry either ! Link to comment Share on other sites More sharing options...
