desertfjr Posted August 17, 2016 Share Posted August 17, 2016 Maybe it's a humidity change here in the humid midwest.... Link to comment Share on other sites More sharing options...
stevesweetz Posted August 29, 2016 Share Posted August 29, 2016 So not to throw a wrench in everyone's theories, but switching to that Motul 7100 full synthetic seemingly has indeed reduced the black spots on the exhaust for me. As mentioned I was taking a big trip, 2400 miles (round trip), visiting Tail of the Dragon in North Carolina. After 1000 miles, my exhaust tip was cleaner than what I'd get after just like 100 miles when on the natrual oil. Maybe coincidental, but anecdotally it seems to have had an effect to me. Link to comment Share on other sites More sharing options...
OUA1 Posted August 29, 2016 Share Posted August 29, 2016 Speaking of said black spots, and apologies for shifting subjects; I have found that acetone removes them moderately well, but still leaves some trace of the fouling. Anyone know what the best solvent to remove those spots might be? Link to comment Share on other sites More sharing options...
bruceintucson Posted August 29, 2016 Share Posted August 29, 2016 Speaking of said black spots, and apologies for shifting subjects; I have found that acetone removes them moderately well, but still leaves some trace of the fouling. Anyone know what the best solvent to remove those spots might be?WD-40 & a rag, followed by SemiChrome metal polish. Link to comment Share on other sites More sharing options...
stevesweetz Posted August 30, 2016 Share Posted August 30, 2016 Yeah I've found both WD-40 and chain cleaner work well. Link to comment Share on other sites More sharing options...
dundee Posted April 20, 2019 Share Posted April 20, 2019 The reason why oils with high zinc additive are deemed "bad" for vehicles with catalytic converters is because if you burn oil, the catalytic converter can be damaged. Firstly, the Yamaha engines do not burn oil, so this should not happen. Secondly, the Rotella T6 does not have any more ZDDP (zinc) than most of the better motorcycle oils, so using T6 is not a greater risk for damaging your catalytic converter. As a quick comparison, Mobil 1 10W40 motorcycle oil has 1200 PPM of zinc while Shell Rotella T6 5W40 has 1095 ppm in the current formulation. Link to comment Share on other sites More sharing options...
brindeld Posted April 22, 2019 Share Posted April 22, 2019 For brand new motorcycles, I would prefer to use the dealers' suggested oil. I don't want to blame myself for using the wrong oil so even if it means spending extra cash, I will take the risk just to make sure that I'm dealing on the right ways. 1 Link to comment Share on other sites More sharing options...
arthur Posted August 17, 2023 Share Posted August 17, 2023 Is it ok to mix mineral and synthetic? Same weight 10-40, same manufacturer liqui moly.... It's not just about the money, it's also the environment.. Link to comment Share on other sites More sharing options...
kilo3 Posted August 17, 2023 Share Posted August 17, 2023 1 hour ago, arthur said: Is it ok to mix mineral and synthetic? Same weight 10-40, same manufacturer liqui moly.... It's not just about the money, it's also the environment.. It all depends where Jupiters moons are in relation to the last new moon on the second tuesday the week after mixing the oil, if neither is visible, just throw that oil out. 3 Link to comment Share on other sites More sharing options...
Ziggy105 Posted August 17, 2023 Share Posted August 17, 2023 1 hour ago, arthur said: Is it ok to mix mineral and synthetic? Same weight 10-40, same manufacturer liqui moly.... It's not just about the money, it's also the environment.. You can mix synthetic and mineral oil but why would you want to when semi-synthetic oil can be purchased off the shelf. Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted August 17, 2023 Supporting Member Share Posted August 17, 2023 Yes. Is this just some left over oil you're mixing? Link to comment Share on other sites More sharing options...
Supporting Member knyte Posted August 17, 2023 Supporting Member Share Posted August 17, 2023 Yes. Most synthetics have a conventional base anyways (group III oils). 2015 FJ-09 / FJR touring bags / oil plug mod / Evotech rad guard / SW Motech bash plate / VStream touring windshield / Seat Concepts: Sport Touring / Vcyclenut ABS rings (speedo correction) / Cosmo RAM mount Link to comment Share on other sites More sharing options...
Ride365 Posted August 18, 2023 Share Posted August 18, 2023 13 hours ago, knyte said: Yes. Most synthetics have a conventional base anyways (group III oils). I'm a base IV kind of guy. Link to comment Share on other sites More sharing options...
