tjjj2006 Posted June 14, 2015 Share Posted June 14, 2015 Hi Just back from a 1500 mile tour round Scotland. Have to say I have now jelled with the Tracer, what a cracking thing it is. a few issues that can be improved but every bike is like that. I have noticed very occasionally and randomly a clonk from the front when going slow and stopping, anyone else had this? Not looked into it yet, i have bounced the front end up and down but cant get it to do it so a strange one, i was thinking sticky fork stantion. :-/ Link to comment Share on other sites More sharing options...
Premium Member wessie Posted June 14, 2015 Premium Member Share Posted June 14, 2015 I have not noticed it on the Tracer but my Super Tenere had the exact symptom you describe. The S10 uses the same technology. I think it was the ABS actuating on the front as the ECU may be worried you are about to lock the wheel then changes its mind once it figures out you are stopping. Certainly never bothered me in 30,000 miles on the S10. I've got into the habit of using the rear brake on the Tracer just before coming to a stop so maybe I am not creating the same scenario as you. This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
tjjj2006 Posted June 14, 2015 Author Share Posted June 14, 2015 Thanks Wessie. That makes a lot of sense, wont worry about it now. Link to comment Share on other sites More sharing options...
FigJam-OhNine Posted June 15, 2015 Share Posted June 15, 2015 It's just the engine crashing into the radiator when you stop. No big deal. Eventually I'm sure it will fall off, but just buy a new engine. No biggie!! Link to comment Share on other sites More sharing options...
mjsracing Posted June 15, 2015 Share Posted June 15, 2015 I hear the sound you describe. Sounds like something is moving a bit, then settling. I've not been concerned enough to investigate. My best guess is that is the two piece front rotor moving just a bit, or the brake pads moving just a bit in the calipers. Does not worry me at all. 2015 FJ-09, 2016 1290 Super Duke, 2017 150 XC-W (primary ride), 2012 DR650 Link to comment Share on other sites More sharing options...
ttownfj09 Posted June 17, 2015 Share Posted June 17, 2015 I've heard it 4 times in my first 1000 miles on the bike. I've looked and can't find anything. I had a 2006 DL 650 Vstrom and it did the same thing for the whole 9 years I owned it and never found the cause with it either. Link to comment Share on other sites More sharing options...
thruster8999 Posted June 17, 2015 Share Posted June 17, 2015 Check to make sure the front wheel axle is tight. If you can spin or move the spacers on either side of the wheel then it is loose. I heard a clunk on mine when I bumped into the handle bars. It took me awhile but found the front to be loose. Tighten her up no more clunk. Link to comment Share on other sites More sharing options...
traceroz Posted June 19, 2015 Share Posted June 19, 2015 I have heard the same noise on mine. I checked the axle, and it was tight. I agree with the comments regarding the brakes. My R1150gs used to make the same noise, as did my ZRX1200. It really only happens at very slow speed, I guess when you are pulling up at a higher speed it happens too quickly to notice. Either way, I'm not concerned. Link to comment Share on other sites More sharing options...
panooch Posted June 19, 2015 Share Posted June 19, 2015 Mine did it for the first time today. Low speed with 1,517 miles while slightly applying the front brake. Must be the pads slightly moving on the pins is my best guess. Nothing is loose. Everyday's a good day when your able to ride 15 FJ-09 - 2WDW ECU flash, Givi SV201, Nelson Rigg tail bag, OES sliders, Koubalink extenders, Ermax Sport, Vista Cruise, OEM seat mod, (smiles) 07 Honda ST1300A (sold) 06 Kawi KLR650 - Big Gun full exhaust, Corbin, Givi, PMR racks, carb mod (keeper) 97 Honda VFR750 - Traxxion Dynamics, Penske, Givi 3 piece, carbon exhaust (keeper?) 20+ years of snowmobiles Link to comment Share on other sites More sharing options...
jbossm7 Posted June 20, 2015 Share Posted June 20, 2015 I have heard it several times. I thought it was just some the plastic in the front flexing or rattling. I guess I was not that concerned. But I know the clunk. Link to comment Share on other sites More sharing options...
xcsp Posted June 20, 2015 Share Posted June 20, 2015 Has anyone re-torqued the steering head bearings to see if that makes any difference, or does it seem like the noise is down low at the wheel? Link to comment Share on other sites More sharing options...
brmidd Posted June 20, 2015 Share Posted June 20, 2015 It's the brake pads. I used to hear it more on my R1's more than my FZ1's. My Honda Accord does it the first time I put on the brakes backing out of the driveway every morning. Link to comment Share on other sites More sharing options...
fattraxx Posted July 11, 2015 Share Posted July 11, 2015 Mine has made that noise a few times now. Sure sounds like the brake pads up front. Link to comment Share on other sites More sharing options...
crfan1 Posted July 11, 2015 Share Posted July 11, 2015 Guys it is caused by the floating brake rotors...my Tiger does the same thing. No worries. Link to comment Share on other sites More sharing options...
Guest branthopolis Posted July 12, 2015 Share Posted July 12, 2015 Brake pads shifting in the calipers... Back out of a parking spot, apply brakes, roll on down the road a bit then apply brakes at speed... CLUNK.. The "float" in a floating brake rotor is side to side... Link to comment Share on other sites More sharing options...
