peteinpa Posted October 8, 2020 Share Posted October 8, 2020 Anything bent?....out of allignment? Link to comment Share on other sites More sharing options...
FJ29ER Posted October 8, 2020 Share Posted October 8, 2020 1 hour ago, peteinpa said: Anything bent?....out of allignment? Nope. So when you put the "sleeve" through the bearing, it can rock in the bearing. So when it compresses it compresses crooked, so it scooted over and was rubbing. It has only been 2-3 weeks since I looked at it last, so 300 ish miles for it to do this. I do have the spring perch on the 2nd to last notch being 250 lbs with gear/luggage so maybe that is at play. Link to comment Share on other sites More sharing options...
peteinpa Posted October 8, 2020 Share Posted October 8, 2020 That sleeve should be tight in the bearing. Sounds like they both need replaced. Can probably buy a kit to replace all those bearings at the same time. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted October 8, 2020 Supporting Member Share Posted October 8, 2020 11 hours ago, peteinpa said: Looks like Yamaha's seemingly too frequent suspension lube and inspection interval is needed. I clean and lube the front swingarm bearings and the linkage bearings every winter. Might be overkill but it only takes an hour for piece of mind. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
FJ29ER Posted October 9, 2020 Share Posted October 9, 2020 16 hours ago, betoney said: I clean and lube the front swingarm bearings and the linkage bearings every winter. Might be overkill but it only takes an hour for piece of mind. Well let this be proof that it is not overkill. I never ride in any moisture and I live in san diego county. This should have been my third time i think. Dryness would be my culprit, not water etc. I am confused though, the bearings are sealed mostly so very little grease would actually get in the rollers. But I guess some is better the none. I still think the bearings could be wider for more support but im no engineer. PS. I love olympia, Sister moved there but after a few years moved to rainier for some more property. So beautiful up there. I always go driving the first or second day just to soak it all in. Little wet for me though haha 1 Link to comment Share on other sites More sharing options...
vincep Posted September 14, 2021 Share Posted September 14, 2021 2019 Tracer 900 GT with 18k miles. I searched for this topic as I have a few mm of travel in the swingarm and is definitely in the dog bone bearings. Has not got progressively worse over the last 5k miles, but I think I will replace the bearings and bushes over the winter. Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted September 15, 2021 Premium Member Share Posted September 15, 2021 Just push it centered after cleaning and greasing. Last service I bought a low mile used link / dog bone assembly for like $35 (I still lubed it), so next service I'll just swap them out. I don't know why they don't have shouldered thrust washers and tighter tolerance to keep the dog bones centered. My Razor R shock doesn't seemingly care though... 1 Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted September 15, 2021 Supporting Member Share Posted September 15, 2021 (edited) On 9/14/2021 at 2:49 PM, vincep said: 2019 Tracer 900 GT with 18k miles. I searched for this topic as I have a few mm of travel in the swingarm and is definitely in the dog bone bearings. Has not got progressively worse over the last 5k miles, but I think I will replace the bearings and bushes over the winter. I have noticed this on my 2015 bike since new (2016), when tightening the axle nut, as you're showing. I am inclined to think that it's normal, or rather a non-issue. The tiny clearance is probably just amplified at the end of the suspended swingarm. The play on my bike hasn't gotten any worse over the years (65K km). Edited September 16, 2021 by piotrek sp Link to comment Share on other sites More sharing options...
vincep Posted September 15, 2021 Share Posted September 15, 2021 @piotrek - yep I am not concerned about it. Have put plenty of miles on it as is. Thanks for your observation/experience. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted September 15, 2021 Supporting Member Share Posted September 15, 2021 9 hours ago, vincep said: 2019 Tracer 900 GT with 18k miles. I searched for this topic as I have a few mm of travel in the swingarm and is definitely in the dog bone bearings. Has not got progressively worse over the last 5k miles, but I think I will replace the bearings and bushes over the winter. 2 hours ago, piotrek said: I have noticed this on my 2015 bike since new (2016), when tightening the axle nut, as you're showing. I am inclined to think that it's normal, or rather a non-issue. Mine definitely does the same thing, my dirtbike is the same even with brand new shock/linkage bearings. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
OZVFR Posted September 15, 2021 Share Posted September 15, 2021 It doesn’t need much play at all on the bearing and linkages to make it look worse on the rear tyre. My VFR, Sprint ST and my Tracer were/are all the same. I clocked up 146,000km on my VFR and 45,000km on the Sprint, never got worse. I don’t think it’s an issue. Link to comment Share on other sites More sharing options...
vincep Posted May 3, 2022 Share Posted May 3, 2022 See my post from Sep 2021 with the video above. I had the bike at Romney Cycles West Virginia for a recall and they stated they would have a look at it. As the bike has the YES extended warranty I said sure. They replaced all the bearings, seals, bolts, spacers and collars in the dog bones. About $200 in parts and three hours labor. Picked up the bike today, the play is still there. No skin off my nose though. 1 Link to comment Share on other sites More sharing options...
