Posted May 19, 20241 yr Who can recommend a lowering kit? For a 2021 model. (Note added 5/19/24 and tell me approx time needed to install? how much did you lower it? Did you need to modify side stand? Center stand? thanks from a height challenged rider Edited May 19, 20241 yr by Don Johnson 21 and newer require diff mods to lower
May 19, 20241 yr Hey Don. This has been discussed many times and if I can suggest that you put "lowering" into the search box you'll get heaps of hits on the subject where I'm thinking your answers will be found. Good luck. Here's a link of mine to get you kicked off in your hunt....
May 19, 20241 yr Hi, @Don Johnson. Great advice from @dazzler24. That is exactly what I did when thinking about lowering my bike. Lots of learning based on shared experiences from members. At the end of the day, I installed 15mm lowering links and moved the forks 15mm up through the triple trees. So far, no need to modify the side stand and it just needs a bit more oomph to hoist it up on the center stand. Pleased with the result so far.
May 19, 20241 yr HYPERPRO worked for me with quick shipping from Europe to the USA and no changes to the center stand. https://webshop-hyperpro.com/?s=&ymm_search=1&post_type=product&_make=YAMAHA&_model=TRACER 9&_year=2021 Top Sellerie has a lowered seat option... https://www.topsellerie.com/en-us/deluxe-seat-SGC7937-yamaha-tracer-9-9-gt-2021_1455.html
