Premium Member keithu Posted July 1, 2015 Premium Member Share Posted July 1, 2015 Strange problem here: Sometimes under hard acceleration my transmission refuses to upshift. I've had it happen between 2-3, 3-4, and 4-5. I pull in the clutch all the way, click up on the shift lever, but it won't move. The problem goes away after double or triple clutching, but it's acting like an old British sports car with bad syncros. Downshifting is no problem, and my shift shaft has the little blue dot indicating the recall has been done. Mileage is 1350 miles. Has anyone else had this? Link to comment Share on other sites More sharing options...
Premium Member keithu Posted July 1, 2015 Author Premium Member Share Posted July 1, 2015 I should add... 90% of the time it shifts fine. It only seems to happen under hard acceleration, but not always even then. Link to comment Share on other sites More sharing options...
avondrei Posted July 1, 2015 Share Posted July 1, 2015 Same here but only between 3-4, quite annoying when it happens. Link to comment Share on other sites More sharing options...
indyfjrider Posted July 2, 2015 Share Posted July 2, 2015 I have that problem from 2 to 3 under hard acceleration sometimes. Let out the clutch and it's still in 2nd. Link to comment Share on other sites More sharing options...
ttownfj09 Posted July 2, 2015 Share Posted July 2, 2015 I've had that happen a few times, when its happened to me I had shifted up and not let the shifter go back down before I tried to shift again. I don't know if its the same thing or not. Link to comment Share on other sites More sharing options...
mjsracing Posted July 2, 2015 Share Posted July 2, 2015 I'm not trying to be funny, Adjust your shift lever up a little. Problem solved. The lever is not returning all the way back down after the previous shift. Do the adjustment. It's quick and easy to undo if it does not help. The reason it is more likely to happen under hard acceleration is that your foot/body position is slightly different. 2015 FJ-09, 2016 1290 Super Duke, 2017 150 XC-W (primary ride), 2012 DR650 Link to comment Share on other sites More sharing options...
troll Posted July 2, 2015 Share Posted July 2, 2015 I'm not trying to be funny, Adjust your shift lever up a little. Problem solved. The lever is not returning all the way back down after the previous shift. Do the adjustment. It's quick and easy to undo if it does not help. The reason it is more likely to happen under hard acceleration is that your foot/body position is slightly different. mjs, I think you have this right. As soon as one realizes this the problem goes away. Coming to you from the frozen wastelands of the barren north Link to comment Share on other sites More sharing options...
avondrei Posted July 2, 2015 Share Posted July 2, 2015 Ahhh... I hate it when something is my own fault, its more fun if I can blame someone Link to comment Share on other sites More sharing options...
Premium Member keithu Posted July 2, 2015 Author Premium Member Share Posted July 2, 2015 I'm not trying to be funny, Adjust your shift lever up a little. Problem solved. Brilliant! I'll try that. Link to comment Share on other sites More sharing options...
trench Posted July 2, 2015 Share Posted July 2, 2015 I can confirm this solves the issue. When your boot is putting pressure on the shifter I can't be changed easily. Some on some other bikes. Link to comment Share on other sites More sharing options...
Guest lawrenceofsuburbia Posted July 3, 2015 Share Posted July 3, 2015 I can confirm this solves the issue. When your boot is putting pressure on the shifter I can't be changed easily. Some on some other bikes.I'm fresh [em](well, three months ago!)[/em] off a series of BMW boxer twins, with their notoriously slow-to-engage gear shifts. I have found that I use an entirely different gear-changing procedure now instead of the clutch-in/ wait a bit/ move the pedal process on the BMWs. Now, I preload the pedal by putting a little foot pressure on it, up or down, then when ready to shift immediately go through with the pressing action, clutch lever pulled right in. I could count on the fingers of one foot how many 'fluffed' changes I've had since adopting this procedure early on, a quick and smooth change always following... FWIW... L of S Link to comment Share on other sites More sharing options...
troll Posted July 3, 2015 Share Posted July 3, 2015 With about 5800km on my FJ the transmission and shifting is as smooth as silk. I moved the shifter to it's upper limit within the first few hundred kilometers to help avoid the hung shift. Once you learn to let the shifter return fully to center after each shift the transmission feels as clean as a whistle. Coming to you from the frozen wastelands of the barren north Link to comment Share on other sites More sharing options...
Premium Member keithu Posted July 13, 2015 Author Premium Member Share Posted July 13, 2015 Follow up: I've ridden about 400 miles since adjusting the shifter up and haven't had a single recurrence. Shifting is now flawless. Thanks for the tips! Link to comment Share on other sites More sharing options...
basstodave Posted July 20, 2015 Share Posted July 20, 2015 I did this adjustment and it is incredible the difference in shifting. I was growing quite frustrated prior with the notchy shifts. This bike is really coming together. Thanks for the tip. Link to comment Share on other sites More sharing options...
basstodave Posted August 24, 2015 Share Posted August 24, 2015 Although I posted an improvement when shifting after adjusting the shift lever height, I find the adjustment makes buttery smooth shifting when I am upshifting at a conservative or docile pace. When accelerating hard the upshift is difficult. Meaning I have to pull up with quite a bit of pressure to get into the next gear. It feels clunky. If this is normal fine but it is quite annoying. I'm trying to figure out what I can do differently but this bike screams to be ridden briskly. Similarly if I accelerate hard in 2nd to move ahead of traffic then would like to upshift and cruise at a lower rpm, I find the upshift difficult and then a huge amount of engine braking until I move up 3 gears. What am I doing wrong? Link to comment Share on other sites More sharing options...
