cthruu Posted July 9, 2015 Share Posted July 9, 2015 Ok- Hopefully someone here can help me out. I picked up a used set of FJR saddlebags and only one of them had a lock. I also purchased the yamaha topcase. I then purchases 2 rekeyable locksets thinking I could rekey and have all 3 keyed alike. They are all keyed alike now but I am missing one piece to the lockset. It is the black aluminum lock cylinder that goes to the saddlebag. The cylinder that comes with the rekey is for the topcase and is different. My only way of getting that piece from yamaha is to buy the 3 piece lock set which is 80 bucks. That is alittle too much to pay for one piece. The thing is- if someone buys the FJR or FJ-09 saddlebags they also have to buy the 3 lock set but only need 2 locks. So there should be at least someone out there with an extra one. I would be willing to buy it from you or I could trade you the parts you would need to rekey your other 2 locks to your engine key if you wanted. 2015 FJ-09 2004 KTM 525 Link to comment Share on other sites More sharing options...
vespadaddy Posted July 9, 2015 Share Posted July 9, 2015 I'm pretty sure I am holding the part in my hand right now. PM me an email address or cell # and I'll text you a photo. I'm in Mpls. Link to comment Share on other sites More sharing options...
Cruizin Posted July 10, 2015 Share Posted July 10, 2015 I'm pretty sure I am holding the part in my hand right now. PM me an email address or cell # and I'll text you a photo. I'm in Mpls. @vespadaddy Tapatalk seems to let you upload photos directly to a post from your phone. Yamaha FZ-10 ForumYamaha FZ-07 ForumYamaha Ténéré 700 Forum Click here to go "ad free" become a supporting member and gain of bunch of forum perks! Link to comment Share on other sites More sharing options...
pixlox Posted July 10, 2015 Share Posted July 10, 2015 I have to ask you how your locks work? I just received my trunk but side bags still waiting on mounting hardware. When the dealer tried installing the one cylinder from my three pack if didn't work the trunk lock. The key only turns 180% to remove it. Of course the trunk from Yamaha needs a key that turns 90% and remove it. Did they send me the wrong locks? Thanks, Mike Link to comment Share on other sites More sharing options...
root Posted July 10, 2015 Share Posted July 10, 2015 I have to ask you how your locks work? I just received my trunk but side bags still waiting on mounting hardware. When the dealer tried installing the one cylinder from my three pack if didn't work the trunk lock. The key only turns 180% to remove it. Of course the trunk from Yamaha needs a key that turns 90% and remove it. Did they send me the wrong locks? Thanks, Mike From the research I've done, the top box takes a different lock than the side cases. I have the lock that you can key to your bike. From what I hear, you can use the left over pieces from that set to re-key the locks in the normal side case set too. I've not figured out why they sell the side case locks in a set of 3 if the top box takes a different lock. Annoying, I know. Link to comment Share on other sites More sharing options...
cthruu Posted July 10, 2015 Author Share Posted July 10, 2015 your sort of in the reverse problem as me. The only difference between them is the black aluminum collar or cylinder that goes around the tumbler part. I have the one you need if you want to trade. I have the one for the top case but need the one for the saddlebags. They are different. 2015 FJ-09 2004 KTM 525 Link to comment Share on other sites More sharing options...
cthruu Posted July 10, 2015 Author Share Posted July 10, 2015 I have to ask you how your locks work? I just received my trunk but side bags still waiting on mounting hardware. When the dealer tried installing the one cylinder from my three pack if didn't work the trunk lock. The key only turns 180% to remove it. Of course the trunk from Yamaha needs a key that turns 90% and remove it. Did they send me the wrong locks? Thanks, Mike From the research I've done, the top box takes a different lock than the side cases. I have the lock that you can key to your bike. From what I hear, you can use the left over pieces from that set to re-key the locks in the normal side case set too. I've not figured out why they sell the side case locks in a set of 3 if the top box takes a different lock. Annoying, I know.The top case comes with a tumbler that uses a shorter key but the tumbler from the 3 key set works- just put it in the topcase cylinder and it works. 2015 FJ-09 2004 KTM 525 Link to comment Share on other sites More sharing options...
vespadaddy Posted July 11, 2015 Share Posted July 11, 2015 Thanks, but I don't use tapatalk. Link to comment Share on other sites More sharing options...
pixlox Posted July 13, 2015 Share Posted July 13, 2015 Thanks Root for your response. I guess I will have to see what my dealer comes up with for now. Presently no side bags mounted and trunk locked on with tie straps. Disappointed with Yamaha at this point. Link to comment Share on other sites More sharing options...
Guest rszk Posted July 13, 2015 Share Posted July 13, 2015 Yea this was disappointing for me too. To me, when you pay that kind of money for the bags, don't you think the locks should come with it, I mean come on Yamaha, who is not going to put locks on their bags. On another note, do not run the Yamaha top box without it secured somehow. If you hit a bump, it is enough to unhinge the box clamping lever and open it so it will actually let the box fly off. This almost happened to me, as I was using it while I was waiting for my proper top box lock to arrive. Link to comment Share on other sites More sharing options...
pixlox Posted July 26, 2015 Share Posted July 26, 2015 Hi: I ended up ordering a cylinder keyed to my ignition for my top box. Do you still need a sidebag lock? Mike Link to comment Share on other sites More sharing options...
cthruu Posted July 27, 2015 Author Share Posted July 27, 2015 Thanks to Vespadaddy I now have working saddlebags. Thanks again. To pay it forward a bit- If anyone needs the tumblers to rekey their cylinders I have a bunch of the tumblers and springs that would probably rekey a couple of cylinders. Just let me know. 2015 FJ-09 2004 KTM 525 Link to comment Share on other sites More sharing options...
root Posted July 27, 2015 Share Posted July 27, 2015 I'll take some of the #2 tumblers if you don't mind. I bought one of the rekeyable locks and planned to use the spare tumblers in the standard sidebag locks, but my key uses a large number of the #2 tumblers. Link to comment Share on other sites More sharing options...
root Posted July 27, 2015 Share Posted July 27, 2015 If you want to make it simple, you can send me all your tumblers. I'll take what I need and send them, along with all my extras on to the next person in line. Even though I'm not ready to buy the side cases, I'll go ahead and get the locks for them right away to rekey them and send the tumblers on their way to the next person. I'll be buying the side cases in a few months. Link to comment Share on other sites More sharing options...
cthruu Posted July 27, 2015 Author Share Posted July 27, 2015 Ok Pm me your address,etc. 2015 FJ-09 2004 KTM 525 Link to comment Share on other sites More sharing options...
