brixdk Posted July 27, 2015 Share Posted July 27, 2015 Hi There I want to hear if anyone knows how I install a relay that can turn off the engine, like when you press the stop button or using the stand I bought a GPS tracker that have the "Remote engine stop", but I can not see the wire to be interrupted or where it is Hope someone can help :-) Link to comment Share on other sites More sharing options...
Premium Member builderbob Posted July 27, 2015 Premium Member Share Posted July 27, 2015 Seems like you'd be able to tap into the kick stand switch pretty easily. Link to comment Share on other sites More sharing options...
brixdk Posted July 27, 2015 Author Share Posted July 27, 2015 Yeaaar :-) But can't see where the black wire goes from the kick stand. Link to comment Share on other sites More sharing options...
Premium Member builderbob Posted July 27, 2015 Premium Member Share Posted July 27, 2015 The starter relay is under the seat. Pull the relay up and look at the wires going into it. The wire to the side stand switch is blue with a black stripe. Link to comment Share on other sites More sharing options...
brixdk Posted July 27, 2015 Author Share Posted July 27, 2015 Cool.... I will try that tomorrow :-D Link to comment Share on other sites More sharing options...
skipperT Posted July 28, 2015 Share Posted July 28, 2015 Kickstand switch will ONLY kill the engine if it is in gear, because of the design of the starting circuit cut off relay and its many diodes. -skip Link to comment Share on other sites More sharing options...
