layduke15 Posted July 28, 2015 Share Posted July 28, 2015 Can anyone confirm with me that Yamaha makes a side bracket that is intended for use with the Yamaha hard side cases? I have contacted local dealers and they told me that they only see the side cases themselves. I want to buy the side brackets and use them for my soft bags to keep them away from the rear tire but don't want to buy the hard bags yet (EXPENSIVE!). Any pictures or part numbers would be great. Thanks. Any other suggestions would also be welcomed. Link to comment Share on other sites More sharing options...
ayrton Posted July 28, 2015 Share Posted July 28, 2015 Yes, just got mine from yamaha with the bags and locks. Link to comment Share on other sites More sharing options...
layduke15 Posted July 28, 2015 Author Share Posted July 28, 2015 Do you know the part number for the side brackets? Link to comment Share on other sites More sharing options...
Premium Member steveb Posted July 28, 2015 Premium Member Share Posted July 28, 2015 Do you know the part number for the side brackets? 2PP-F84G0-V0-00 HARD SADDLEBAG MOUNT (FJ-09 lower hard saddlebag mounts) Check out the FJR Saddlebags on FJ thread for more info. Enjoy! Link to comment Share on other sites More sharing options...
Premium Member estell Posted August 6, 2015 Premium Member Share Posted August 6, 2015 I want to buy the side brackets and use them for my soft bags to keep them away from the rear tire I had planned to do the same but my dealer talked me out of it. The parts guy said he didn't think it would work well. I ended up fabricating some brackets of my own. Post back if it works for you. 2015 red FJ-09: Cal Sci screen, Sargent seat, ECU flash, slider combo, cruise, Rizoma bars, Matts forks, JRi shock, slipper clutch Link to comment Share on other sites More sharing options...
Supporting Member 1moreroad Posted August 16, 2015 Supporting Member Share Posted August 16, 2015 I want to buy the side brackets and use them for my soft bags to keep them away from the rear tire I had planned to do the same but my dealer talked me out of it. The parts guy said he didn't think it would work well. I ended up fabricating some brackets of my own. Post back if it works for you. I'll agree. There are good photos on this site of the brackets. The brackets probably don't extend high enough to do what you want. They're also relatively heavy to anchor side bags. You don't need that weight if you're just holding soft bags away from the tire. Link to comment Share on other sites More sharing options...
