zimbob Posted August 8, 2015 Share Posted August 8, 2015 This finally came back in stock Revzilla $74 free shipping. Easy install.I was able to use my old 45 litre case has the back rest my passenger said its perfect. http://imgur.com/oyPX9bE Link to comment Share on other sites More sharing options...
Premium Member wessie Posted August 8, 2015 Premium Member Share Posted August 8, 2015 snap This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
com3 Posted November 21, 2015 Share Posted November 21, 2015 Does it work with the factory hard bags in place? Link to comment Share on other sites More sharing options...
Premium Member foxedupone Posted November 21, 2015 Premium Member Share Posted November 21, 2015 Did the mount sr2122 come with the mono key plate or do you get that separate? I was confused when considering ordering this. Link to comment Share on other sites More sharing options...
zachd Posted November 21, 2015 Share Posted November 21, 2015 Did the mount sr2122 come with the mono key plate or do you get that separate? I was confused when considering ordering this.You will install the SR2122, and you'll also need to buy an adapter plate for the topcase. If you are using a Givi Monokey case, than the M5 or M7 plate will work. I installed the M5. The M7 is newer, and would probably look better. Also installed are the Givi sidecase mounts. Link to comment Share on other sites More sharing options...
Premium Member wessie Posted November 21, 2015 Premium Member Share Posted November 21, 2015 I have the same set-up as @zachd then use an E45 box on the topbox plate and if touring, Kappa K40 cases on the sides. Kappa is made by Givi and uses the same Monokey system. A K40 case can be used as a topbox to provided added flexibility. This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
Premium Member foxedupone Posted November 21, 2015 Premium Member Share Posted November 21, 2015 Thanks I'll order the mount and m7 plate since I already have givi boxes on my other bikes. Link to comment Share on other sites More sharing options...
zachd Posted November 22, 2015 Share Posted November 22, 2015 You'll love it! I love my setup. Make sure to retighten all bolts from the install after 50-100 miles, as mine came loosened ever so slightly. Throwing on some blue loctite will help mitigate this issue as well. Link to comment Share on other sites More sharing options...
