Premium Member steveb Posted August 13, 2015 Premium Member Share Posted August 13, 2015 Had a Aha / Duh moment today while out riding. This may be old news to some but I didn't see anything mentioned about it in older posts. I was riding around in Std mode and wanted to be in A mode. No stop signs or red lights were on the horizon, and I didn't feel like stopping just to change the mode. I wasn't sure if the ability to change the mode was controlled by speed or rpm. As an experiment I pulled in the clutch (coasting along at about 60mph) closed the throttle and, when the rpm dropped to idle, pushed the mode button and I was now in A. Rolled the throttle back up, let the clutch out and continued on happily riding in A mode (which is rapidly becoming my most commonly used mode since my ECU flash). Just an FYI for those who hadn't thought about this yet either. Link to comment Share on other sites More sharing options...
toast Posted August 13, 2015 Share Posted August 13, 2015 Yep, just close the throttle to change modes . You still need to be in neutral to turn of the TCS though. Link to comment Share on other sites More sharing options...
root Posted August 13, 2015 Share Posted August 13, 2015 Yeah, you don't even need to pull the clutch if you don't want to. Just need the throttle closed as @toast mentioned. Link to comment Share on other sites More sharing options...
