Premium Member kyleht Posted September 18, 2015 Author Premium Member Share Posted September 18, 2015 actory internals and factory rear spring the front has all new internals with gold valves and the rear shock is sealed so it can't be re valved but they resprung it for my weight Link to comment Share on other sites More sharing options...
Premium Member kyleht Posted September 18, 2015 Author Premium Member Share Posted September 18, 2015 Link to comment Share on other sites More sharing options...
Premium Member peporter Posted September 18, 2015 Premium Member Share Posted September 18, 2015 Got my suspension back from race tech yesterday and man is it incredible the difference. I have only rode around town so far and I have already fell in love with the bike again.What specifically do you like about it? Link to comment Share on other sites More sharing options...
pattonme Posted September 18, 2015 Share Posted September 18, 2015 They also should have included a Valve sheet with Cxx and Ryy settings. And if you were the guinea pig they really should have given you a dyno graph. Link to comment Share on other sites More sharing options...
Premium Member jeff400650 Posted September 18, 2015 Premium Member Share Posted September 18, 2015 Thanks for this info. I am curious for comparison, what are the spring rates for the factory fork and shock? Pistons or pedals, 2 wheels are where it's at... Link to comment Share on other sites More sharing options...
cretin Posted September 20, 2015 Share Posted September 20, 2015 [attachment id=168" thumbnail="1]actory internals and factory rear spring the front has all new internals with gold valves and the rear shock is sealed so it can't be re valved but they resprung it for my weight How much did it set you back? Link to comment Share on other sites More sharing options...
Premium Member kyleht Posted September 23, 2015 Author Premium Member Share Posted September 23, 2015 The one sheet is all they gave me. It cost me $500. My favorite part about it is it controls the front end dive when braking and coming into a corner and it feels much mor confident carrying through a corner. I definitely recommend any type of suspension upgrade. I fell in love with the bike again since putting it on. Link to comment Share on other sites More sharing options...
pattonme Posted September 23, 2015 Share Posted September 23, 2015 I would call them back. You're in the computer now. Ask them for specifics as to what was done. It should go like this: "we installed 2 gold valves, 1 each base valve and rebound in the one leg. We used C3x and R2x shim configuration. We changed the oil and spring in the other leg but otherwise made no changes (Ed. would be nice if they had put a base valve in and also put the Kayaba valve holder on the end and installed the other half of the GV pair...) On your shock we ....." Link to comment Share on other sites More sharing options...
cowboyrog Posted September 24, 2015 Share Posted September 24, 2015 What exactly did race tech do? forks and shock? What shock? Details, details, inquiring minds want to know!!! Link to comment Share on other sites More sharing options...
mmandell Posted September 25, 2015 Share Posted September 25, 2015 Race Tech doesn't yet have a shock replacement so they replace the spring. Link to comment Share on other sites More sharing options...
Kurgan Posted November 4, 2015 Share Posted November 4, 2015 Interesting that for a 200 pound rider, they used 1.1kg/mm fork springs. On one of my last bikes which weighs 40 pounds more than an FJ and with me at 260 pounds, 1.0 kg/mm fork worked well on the street. Link to comment Share on other sites More sharing options...
pattonme Posted November 4, 2015 Share Posted November 4, 2015 yeah definitely curious. I would have said 0.95 was plenty and might have recommended 0.925 frankly. What sag numbers are you working with? Link to comment Share on other sites More sharing options...
norwest Posted November 4, 2015 Share Posted November 4, 2015 Yeah seems strange here as well, With an upright riding position and the 462 est wet weight that seems like it is running a pretty heavy spring for a 200# rider. Interesting note is even their calculator recommends a .95 kg/mm rate. I would recommend calling back in or taking it back in and asking why they used that rate in your forks when they recommend a .95 for your weight on their calculator. Call in and ask to speak with Sydney as she is the service manager. pattonme, The normal reason they don't give a stack number is the stack they use would not correspond to anything they have in the tables as the R&D guy comes up with his own stacks and then the DVS gives customers a different stack configuration. Terry Link to comment Share on other sites More sharing options...
patsmith Posted December 31, 2015 Share Posted December 31, 2015 Can you be specific with what they changed in the valving? Did you get compression while keeping rebound in the forks? Did you get compression in the shock? Link to comment Share on other sites More sharing options...
bobaintstoppin Posted April 9, 2016 Share Posted April 9, 2016 I'm in the process of installing the Race Tech valves in the front forks. Also 0.95 springs. Have to say the instructions from Race Tech are not for the amateur garage jockey. i've been working on machines for many years. Also did a Race Tech fork job on my F800ST without problems. But this is my first adventure inside an upside down fork. So I have things apart and have the cartridges assembly on the bench. I assume the valving is inside this, but it doesn't want to come apart. I've put some considerable force on things and nothing budges. Don't want to damage anything, so allow me to ask for advice on how to get the cartridge apart. In reading the ULEWZ thread on the Adrian kit, it looks like they supply the entire cartridge assembly. So how does one go about getting inside this thing? Any pics or description available? Thanks for any assistance. Link to comment Share on other sites More sharing options...
