Premium Member martyl Posted January 3, 2016 Author Premium Member Share Posted January 3, 2016 New question; my left hand hand guard is slightly lower than my right hand guard. I have an Ermax touring sport windshield and because the left hand guard set up slightly lower (tilted down) its hitting the windshield. How to I readjust the hand guard? There is a bolt facing me under the mirror stem and the hex bolt at the end of the guard. Do I just loosen those two bolts? Is there a toque spec for them? Thanks... A Motorcyclist's Church is the open road.... Link to comment Share on other sites More sharing options...
Premium Member Trambo Posted January 3, 2016 Premium Member Share Posted January 3, 2016 New question; my left hand hand guard is slightly lower than my right hand guard. I have an Ermax touring sport windshield and because the left hand guard set up slightly lower (tilted down) its hitting the windshield. How to I readjust the hand guard? There is a bolt facing me under the mirror stem and the hex bolt at the end of the guard. Do I just loosen those two bolts? Is there a toque spec for them? Thanks...Torque as shown: Looks like 7Lb/Ft for those. Careful as the damn things are made of swiss cheese. Edit - this is the brake side, but torque values are the same on the 2 clutch side retaining bolts shown on 13. 2015 Stealth Grey FJ-09 Pilot Base of Operations: Chesterfield, VA Farkels? Lots, nothing flashy, but all functional... Link to comment Share on other sites More sharing options...
Premium Member Trambo Posted January 3, 2016 Premium Member Share Posted January 3, 2016 This diagram might help: 2015 Stealth Grey FJ-09 Pilot Base of Operations: Chesterfield, VA Farkels? Lots, nothing flashy, but all functional... Link to comment Share on other sites More sharing options...
Premium Member martyl Posted January 3, 2016 Author Premium Member Share Posted January 3, 2016 Thanks! So I can assume that loosening the two number 13 bolts and the bolt at the end of the hand guard will allow me to pivot the whole hand guard and clutch lever? A Motorcyclist's Church is the open road.... Link to comment Share on other sites More sharing options...
Premium Member Trambo Posted January 3, 2016 Premium Member Share Posted January 3, 2016 Thanks! So I can assume that loosening the two number 13 bolts and the bolt at the end of the hand guard will allow me to pivot the whole hand guard and clutch lever?On the throttle side, yes. On the clutch side, there's just one 8mm bolt facing rider position that needs loosened to rotate the clutch lever slightly to drop the hand guard a bit. This one shown just above the number 13: 2015 Stealth Grey FJ-09 Pilot Base of Operations: Chesterfield, VA Farkels? Lots, nothing flashy, but all functional... Link to comment Share on other sites More sharing options...
Premium Member Trambo Posted January 3, 2016 Premium Member Share Posted January 3, 2016 It's good knowing how to adjust the hand levers on a bike. I do this with every new bike I buy, getting the levers to a comfortable position for my hands is pretty important to me. Foot levers / shifter as well. Having them set to your body size & position is a smart move that improves comfort & rider safety. 2015 Stealth Grey FJ-09 Pilot Base of Operations: Chesterfield, VA Farkels? Lots, nothing flashy, but all functional... Link to comment Share on other sites More sharing options...
Premium Member martyl Posted January 13, 2016 Author Premium Member Share Posted January 13, 2016 Made the adjustment today. Still just touching the edge of the Ermax tall sport windshield when I turn all the way to the right. I may have to trim the windshield a little. More to follow... Just loving the FJ09. I'm at around 3800 miles. I can feel she's breaking in. Time to start planning some trips. Here in Central Florida this morning it was 40 degrees out. I like it brisk but now thinking about getting the heated grips... Life is good.... A Motorcyclist's Church is the open road.... Link to comment Share on other sites More sharing options...
suncoaster Posted January 13, 2016 Share Posted January 13, 2016 Rather than trim the screen maybe the ebay handguard spacer brackets will work ? Link to comment Share on other sites More sharing options...
