Premium Member peporter Posted April 21, 2017 Premium Member Share Posted April 21, 2017 Yes the dog leg goes on chain side, straight disc side. Mine didnt have rubber grommets. Here are some pics hope it helps. If you need pics or have other questions let me know. I mis-spoke about the grommets, they are nylon counter sinks. Also, my kit had white nylon washers. Do they go between the hugger and the dog leg and straight plates? Did you leave the spacer in at the center bolt? My concern is the bolt bottoming out before it snugs up, and then it affects the alignment of everything else. Even without the spacer, the two front side bolts are a hassle. Thanks for the help. Those are some nice axle adjusters also! Who makes them? Link to comment Share on other sites More sharing options...
thruster8999 Posted April 21, 2017 Share Posted April 21, 2017 The nylon washers go between the bolts an outside hugger should be 3 or 4 white washers. Link to comment Share on other sites More sharing options...
thruster8999 Posted April 21, 2017 Share Posted April 21, 2017 Lightech makes chain adjusters which make adjustments easier. Not sure I understand the bottoming out issue. The black counter sink ones go between the hugger and bolt just like the picture and the nylon ones are the three front bolts towards the front. The inside brackets just have the bolts. Let me know what pics you need on the area you are having problems and I will try my best to get a clear shot for you. Also make sure you use blue loctic on all bolts. Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted May 16, 2017 Premium Member Share Posted May 16, 2017 I read the entire thread but no one indicated how much it costs either unpainted and painted? So how muchy? Link to comment Share on other sites More sharing options...
xcsp Posted May 17, 2017 Share Posted May 17, 2017 I read the entire thread but no one indicated how much it costs either unpainted and painted? So how muchy? For the JMV Hugger? Last time I checked with the currency conversion it was around $280. Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted May 17, 2017 Premium Member Share Posted May 17, 2017 I emailed them and this is the reply I got today translated from the French. At least they're responsive but too rich for my blood. Hello the price of the rear fender is painted 211.00 euros the shipping cost is 50.00 euros the delivery time is 15 days receipt of payment paypal has ultime.concept@orange.fr Best regards There is also the R&G racing full hugger but it's still too much money for me even though it probably is pretty good but Revzilla sells it for more than list and I only found a bit less direct from GB. https://www.revzilla.com/motorcycle/rg-racing-rear-hugger-yamaha-fz-09-fj-09-xsr900 What prompted this search was last year I had made a hugger extender from ABS (see photos) but it snapped off after about 8,000 miles last weekend. I also made a shock mud flap but having the Shad SH36 instead of the much smaller OEM side cases (see this thread https://fj-09.org/thread/526/flap-protect-rear-shock-road), I had no cross member to attach the mud flap and instead had to bond it to the frame above the swing arm. However, my mud flap blew around and impinged on the swing arm, so I removed it. Despite its acute angle and not smothering the fly-off like a hockey goalie leaving the net on a break-away, my extender worked pretty well. In the interim yesterday I installed the aluminum extender I bought and used as a template for mine but at triple the length. So I negotiated a price for the real Pyramid CF extender in the below link. But it will take a while to get here from jolly ole England. I found the same extender made of polypropylene for only a few dollars less so I opted for the CF unit for a bit of bling that is sympathetic to the mock CF on the FJ-09. He gave me 10% off what its buy now price. I'm going to use 3M doubled-side exterior tape after I thoroughly clean the mating surfaces and again use the screws and nuts as a belt and suspenders (after potting with epoxy the holes I'll drill in the CF extender), since I already drilled the OEM hugger. http://www.ebay.com/itm/122482132487?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT Link to comment Share on other sites More sharing options...
