Premium Member smiley Posted August 9, 2016 Author Premium Member Share Posted August 9, 2016 These are the empty connectors that are on/off with the key. Hi @smiley I have the same GPS, Garmin 669, finally, which conexion has you used? white? black? "yellowW? Hi Dan77, I used the one in the right of your picture.(The yellow) I tested the the 2 on the left and they would work but I did not have connectors. Jon Link to comment Share on other sites More sharing options...
dan77 Posted August 9, 2016 Share Posted August 9, 2016 Hi @smiley I have the same GPS, Garmin 669, finally, which conexion has you used? white? black? "yellowW? Hi Dan77, I used the one in the right of your picture.(The yellow) I tested the the 2 on the left and they would work but I did not have connectors. many thanks smiley for your answer. Then I have an extra question, did you buy some connector to use the yellow one (the right of picture)? because we have just two cables in GPS: many thanks. Link to comment Share on other sites More sharing options...
stevesweetz Posted August 9, 2016 Share Posted August 9, 2016 FWIW I think it would take quite a while for it to drain the battery. I had a GPS hardwired to my CBR500R battery and let it sit for over an hour, mistakenly forgetting to remove it, and the bike started fine. Normally any time I'd be letting my bike sit that long I'd take the GPS off to prevent it from being stolen anyway. Anyway, good to hear that the wire can be routed from the battery without having to remove the tank. I need to do that this weekend. With the FJ I have been using a car GPS with the accessory power port, but I finally got a Zumo in preparation for a proper big trip so I need to use their battery cable. Link to comment Share on other sites More sharing options...
Premium Member smiley Posted August 9, 2016 Author Premium Member Share Posted August 9, 2016 . many thanks smiley for your answer. Then I have an extra question, did you buy some connector to use the yellow one (the right of picture)? because we have just two cables in GPS: many thanks. I did not have the connector either. I cut the end off of the extra DC power outlet that I had installed and sliced it in. ( I really didn't need 2 anyway) I have since ordered extra connectors and will put an end back on the DC outlet when I get around to it. Jon Link to comment Share on other sites More sharing options...
Premium Member smiley Posted August 10, 2016 Author Premium Member Share Posted August 10, 2016 many thanks smiley for your answer. Then I have an extra question, did you buy some connector to use the yellow one (the right of picture)? because we have just two cables in GPS: Dan, this is where I ordered the extra connectors from. http://www.cycleterminal.com/motorcycle-connectors.html Jon Link to comment Share on other sites More sharing options...
dan77 Posted August 10, 2016 Share Posted August 10, 2016 many thanks smiley for your answer. Then I have an extra question, did you buy some connector to use the yellow one (the right of picture)? because we have just two cables in GPS: Dan, this is where I ordered the extra connectors from. http://www.cycleterminal.com/motorcycle-connectors.html Many thanks smiley!! Link to comment Share on other sites More sharing options...
desilva Posted April 15, 2017 Share Posted April 15, 2017 many thanks smiley for your answer. Then I have an extra question, did you buy some connector to use the yellow one (the right of picture)? because we have just two cables in GPS: Dan, this is where I ordered the extra connectors from. http://www.cycleterminal.com/motorcycle-connectors.html Smiley, Dan, Which exact connector (or set of connectors) did you end up buying? The page has a bunch of them and I am new to this stuff, so dont know which exact connector to use? I have a Garmin Zumo 590LM and it has 4 wires coming out of the GPS motorcycle mount, so have to also find a way to deal with the other wires which are of no use to me... Many thanks for your help guys! Arvind. Link to comment Share on other sites More sharing options...
Premium Member smiley Posted April 16, 2017 Author Premium Member Share Posted April 16, 2017 Dan, this is where I ordered the extra connectors from. http://www.cycleterminal.com/motorcycle-connectors.html Smiley, Dan, Which exact connector (or set of connectors) did you end up buying? The page has a bunch of them and I am new to this stuff, so dont know which exact connector to use? I have a Garmin Zumo 590LM and it has 4 wires coming out of the GPS motorcycle mount, so have to also find a way to deal with the other wires which are of no use to me... Many thanks for your help guys! Arvind. Jon Link to comment Share on other sites More sharing options...
desilva Posted April 16, 2017 Share Posted April 16, 2017 Thanks Jon, Did you need all of the items in the screenshot for just the GPS install? Thanks! Arvind. Link to comment Share on other sites More sharing options...
Premium Member smiley Posted April 17, 2017 Author Premium Member Share Posted April 17, 2017 Thanks Jon, Did you need all of the items in the screenshot for just the GPS install? Thanks! Arvind. You are welcome. I did not need all the items...figured I would just get some extras. Jon Link to comment Share on other sites More sharing options...
desilva Posted April 17, 2017 Share Posted April 17, 2017 Jon, I'm a total noob when it comes to electricals... could you please specify what exact parts you got for the GPS Install only? I'm also seeing a possibility to add LED aftermarket lights and was wondering what connectors to buy for those? I'm assuming that there are 3 open spots available - 2 for lights and 1 for the GPS (or the second cigarette plug) based on an image someone had posted in another thread. Again, sincere thanks! :-) Arvind. Link to comment Share on other sites More sharing options...
BBB Posted April 17, 2017 Share Posted April 17, 2017 Arvind, if you look at the picture in the last post on page 2 of this thread, you'll see two grey connectors. Yamaha has put the connectors you need, actually in the sockets already. The male part of the socket is already there, blanked off with two rubber grommets where the wires go in. Some people have had luck with simply pushing wires into the socket. I bought a similar looking socket and took the internal metal parts out and put them into the Yamaha socket when I wired in LED lights on th the handguards. Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
desilva Posted May 2, 2017 Share Posted May 2, 2017 Hello All, Just wanted to provide a quick update.... I finally ended up direct wiring my GPS to the battery.... remove the panels on the right and was able to zip tie the bunch of cables (of the Zumo 590LM) tightly enough and place them along the right lower faux carbon fiber looking panel... tight fit but a decent fit. I still might need to open up the windshield base to access and fit LED lights once I decide to get them! :-) the farkling never ends, does it? Thanks to you guys for ideas and possibilities... this forum has a wealth of information and I'm glad to be a part of it! Arvind Link to comment Share on other sites More sharing options...
