backmarker Posted May 18, 2016 Share Posted May 18, 2016 Thanks for the photos, "beburle", as they are going to be very useful, as it's not immediately obvious how to remove those side panels! Link to comment Share on other sites More sharing options...
Supporting Member Heli ATP Posted February 21, 2021 Supporting Member Share Posted February 21, 2021 Started my MCCruise install today which requires removal of the fuel tank. Had a hard time removing the fuel pressure hose. Seems the connector on my 2017 is a little bit different than the orange and blue pictured earlier in this thread. Here is a pic I found on the FZ-09 forum (credit to excess-arrr-rider) that covers my connector. Insert flat head screwdriver and twist does the trick. I really had to pull hard on the overflow and vent hoses to get those off. I had seen where someone else had just left them on and rerouted them down later, but a good pull and they came off. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted February 21, 2021 Supporting Member Share Posted February 21, 2021 5 minutes ago, Heli ATP said: Started my MCCruise install today which requires removal of the fuel tank. Had a hard time removing the fuel pressure hose. Seems the connector on my 2017 is a little bit different than the orange and blue pictured earlier in this thread. Here is a pic I found on the FZ-09 forum (credit to excess-arrr-rider) that covers my connector. Insert flat head screwdriver and twist does the trick. I really had to pull hard on the overflow and vent hoses to get those off. I had seen where someone else had just left them on and rerouted them down later, but a good pull and they came off. That connector can be frustrating at times but they make specialty pliers just for that task. Performance Tool W83115 Fuel Line Clip Removal Pliers | JB Tool Sales Buy Performance Tool W83115 Fuel Line Clip Removal Pliers with an... 2 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted February 22, 2021 Supporting Member Share Posted February 22, 2021 (edited) 3 hours ago, betoney said: That connector can be frustrating at times but they make specialty pliers just for that task. Have these and they work very well on my 2015... but to my surprise, the 2017 indeed had a different fitting on there. Found out when working on my buddy's bike. Different trickery required. Edited February 22, 2021 by piotrek 2 Link to comment Share on other sites More sharing options...
