mjsracing Posted November 21, 2015 Share Posted November 21, 2015 Help please. When I started to remove the oil fill cap on the side of the engine, there was a lot of pressure built up inside the crank case. Hissing sound when i started to loosen the cap, then it almost shot out of the engine as I got it fully unscrewed. I had just washed the bike and let it idle for 5 minutes in the stand. I'm sure that is not normal. Any thoughts about the cause and solution? Thanks in advance! 2015 FJ-09, 2016 1290 Super Duke, 2017 150 XC-W (primary ride), 2012 DR650 Link to comment Share on other sites More sharing options...
Premium Member wessie Posted November 21, 2015 Premium Member Share Posted November 21, 2015 Is there a crank case breather into the airbox? If so, is the pipe kinked or blocked? Many bikes will blow excess oil into the airbox if overfilled. Quite common on BMW boxer engines as people misread the instruction on checking the sight glass, then overfill the engine. This can lead to the pipe clogging. I doubt this would have happened on the Tracer as the oil check is more straightforward plus the bike is relatively new. This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
mjsracing Posted November 21, 2015 Author Share Posted November 21, 2015 Wessie, you were correct. Local dealership kinked the breather hose after syncing the carbs. Symptoms also included oil consumption. Thanks for you help! Problem solved. 2015 FJ-09, 2016 1290 Super Duke, 2017 150 XC-W (primary ride), 2012 DR650 Link to comment Share on other sites More sharing options...
Premium Member wessie Posted November 21, 2015 Premium Member Share Posted November 21, 2015 and some people would have me banned! Glad it was easy to fix. This is what happens when the tank & airbox is twisted rather than removed to get access to the throttle bodies. I'll add a warning to the throttle sync thread. Now, where did the oil go when the pressure built up? Have you had to top up much? Hopefully it just got burnt off somewhere and the clutch is wet so unlike a BMW, you won't have blown a clutch seal... This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
Buggy Nate Posted November 22, 2015 Share Posted November 22, 2015 and some people would have me banned! Glad it was easy to fix. This is what happens when the tank & airbox is twisted rather than removed to get access to the throttle bodies. I'll add a warning to the throttle sync thread. Now, where did the oil go when the pressure built up? Have you had to top up much? Hopefully it just got burnt off somewhere and the clutch is wet so unlike a BMW, you won't have blown a clutch seal... Have you banned?? Why? Your posts are great! The flag is like a big warning that sarcasm is here! I love it! Bloody piss poor work from the dealers.. Link to comment Share on other sites More sharing options...
Premium Member wessie Posted November 22, 2015 Premium Member Share Posted November 22, 2015 and some people would have me banned! Glad it was easy to fix. This is what happens when the tank & airbox is twisted rather than removed to get access to the throttle bodies. I'll add a warning to the throttle sync thread. Now, where did the oil go when the pressure built up? Have you had to top up much? Hopefully it just got burnt off somewhere and the clutch is wet so unlike a BMW, you won't have blown a clutch seal... Have you banned?? Why? Your posts are great! The flag is like a big warning that sarcasm is here! I love it! Bloody piss poor work from the dealers.. Thankyou for your adulation. I'll add it to the others in my portfolio. The rainbow flag? That means something completely different, sweetie. This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
Buggy Nate Posted November 22, 2015 Share Posted November 22, 2015 Hahaha I know what it means mate, I do the Mardi Gras every year with the dykes on bikes as a support crew if they crash or breakdown, always a entertaining night! Link to comment Share on other sites More sharing options...
