gdm Posted December 21, 2015 Share Posted December 21, 2015 For those of you that have the OEM rack are you able to mount a soft bag to it. I can't tell from the pictures if one is able to loop straps around the rails to attach a bag. I have a Wolfman peak tail bag I would like to attach to the bike. Thanks for any info.. Link to comment Share on other sites More sharing options...
skipperT Posted December 22, 2015 Share Posted December 22, 2015 Hi GDM- Mounting a small tailback is doable. The footprint of the rack is rather small, so I would measure the base of the bag you are planning on using. It does not have tie down points like the side rails on the FJ. What I did was mount the loop straps underneath the rack on the tubing that supports it. Hth- Skip Link to comment Share on other sites More sharing options...
gdm Posted December 23, 2015 Author Share Posted December 23, 2015 Thanks for the info. skip. I was wondering if there was enough space to run straps under the rack. Link to comment Share on other sites More sharing options...
skipperT Posted December 23, 2015 Share Posted December 23, 2015 Thanks for the info. skip. I was wondering if there was enough space to run straps under the rack. Barely. It's a tight squeeze. Loosening up the attaching hardware for the rack where it bolts to the support might allow you more room. Do you have one that you could look at? A visual might help. Skip Link to comment Share on other sites More sharing options...
gdm Posted December 23, 2015 Author Share Posted December 23, 2015 Don't know anyone who has one. Maybe I could find a good close up photo. Link to comment Share on other sites More sharing options...
