rickrides Posted May 21, 2016 Share Posted May 21, 2016 I have installed Renthal Streetfighter bars on my wife's FJ09 and bought a pair for my bike as well. Installation was pretty simple but, if you are going to install the stock hand guards you will need to have someone tap the new bars so you can screw the plug on the end of the stock bars into the Renthal bars. If you are not using the handguards, you will need to move the holes you will need to drill for the controls in about 1/2" per side to account for removal of the plug that threads into the end of the stock bars. Don't ask how I know. All cables, etc., fit fine with the new bars. After riding my wife's bike for about an hour straight today, I'd say the thumb pain issue is about 75-80% solved. Left was fine and just a slight bit of pain in the right. I think I will mount my controls a bit more inboard when I do my bike and see if that cures the issue. If so, I'll modify my wife's bike as well. I did not account for the loss of the plug at the end of the bars on her bike so her grips stick out over the end of the bars a bit. I will be installing bar end weights. Link to comment Share on other sites More sharing options...
docsimple Posted May 27, 2016 Share Posted May 27, 2016 I went with these in stainless steel, long: http://www.satoracing.com/handlebarend.htm very pleased with the weight and quality. I have installed Renthal Streetfighter bars on my wife's FJ09 and bought a pair for my bike as well. Installation was pretty simple but, if you are going to install the stock hand guards you will need to have someone tap the new bars so you can screw the plug on the end of the stock bars into the Renthal bars. If you are not using the handguards, you will need to move the holes you will need to drill for the controls in about 1/2" per side to account for removal of the plug that threads into the end of the stock bars. Don't ask how I know. All cables, etc., fit fine with the new bars. After riding my wife's bike for about an hour straight today, I'd say the thumb pain issue is about 75-80% solved. Left was fine and just a slight bit of pain in the right. I think I will mount my controls a bit more inboard when I do my bike and see if that cures the issue. If so, I'll modify my wife's bike as well. I did not account for the loss of the plug at the end of the bars on her bike so her grips stick out over the end of the bars a bit. I will be installing bar end weights. 2015 Red FJ 09 2013 WR250R - little boy blue - sold 2012 DL650 V Strom - sold 2007 FZ6 - sold 1986 FJ600 - sold Link to comment Share on other sites More sharing options...
Premium Member bugsplatered Posted May 27, 2016 Premium Member Share Posted May 27, 2016 docsimple, did the bar ends decrease vibration any? Link to comment Share on other sites More sharing options...
docsimple Posted May 27, 2016 Share Posted May 27, 2016 some, but my bars are not the stockers. I used the Raptor bars. And I had to replace all the cabling to make it work. Im not into stretching those lines. But yes, some. I was considering grip puppies and filling the bars with shot or silicone. 2015 Red FJ 09 2013 WR250R - little boy blue - sold 2012 DL650 V Strom - sold 2007 FZ6 - sold 1986 FJ600 - sold Link to comment Share on other sites More sharing options...
Premium Member fddriver2 Posted May 28, 2016 Premium Member Share Posted May 28, 2016 I have Grip Puppies. They work pretty well for the money spent. Not perfect, but certainly an improvement. "It doesn't matter who walks in, you know the joke is still the same" Ft. Lauderdale, Florida. USA Link to comment Share on other sites More sharing options...
allbikes Posted June 3, 2017 Share Posted June 3, 2017 Dencos, You mentioned a triumph project? How about a 70 bonnie? In tiger gold? I really want to have someone build this bike for my 76 year old father. It's all original and in need of a carb tune and sync some other TLC. Thoughts? Link to comment Share on other sites More sharing options...
allbikes Posted June 17, 2017 Share Posted June 17, 2017 For what it's worth I too had the same problem. However, I went with Rox 1-3/4 x 1- 1/8 risers and it all worked perfectly. 86.00 and :30 mins I was on the road with a swept back set of bars. Link to comment Share on other sites More sharing options...
oldenough Posted June 26, 2017 Share Posted June 26, 2017 I picked up my new, 2017 FJ 09 last Saturday and just noticed that the handlebars seem to be rotated forward just enough to put the top of the hand guards level with the grips so that the top of my hands are above the top of the guards. Worse, I'm reaching down for the clutch and brake so that I have to keep my hands pointing down instead of flat, as I prefer them. Is this normal? Can I just loosen the bolts and rotate the handlebar so that my hands can be flat? Many thanks for any advice on this. Link to comment Share on other sites More sharing options...
wordsmith Posted June 26, 2017 Share Posted June 26, 2017 I picked up my new, 2017 FJ 09 last Saturday and just noticed that the handlebars seem to be rotated forward just enough to put the top of the hand guards level with the grips so that the top of my hands are above the top of the guards. Worse, I'm reaching down for the clutch and brake so that I have to keep my hands pointing down instead of flat, as I prefer them. Is this normal? Can I just loosen the bolts and rotate the handlebar so that my hands can be flat? Many thanks for any advice on this. Happens every time it seems - sloppy pre-delivery prep by dealer. Yes - just do what you suggest above, then adjust the mirrors on the stalks accordingly.. Riding a fully-farkled 2019 MT-09 Tracer 900 GT from my bayside home in South East Queensland, Australia. Link to comment Share on other sites More sharing options...
oldenough Posted June 26, 2017 Share Posted June 26, 2017 Thanks! Link to comment Share on other sites More sharing options...
dencos Posted June 27, 2017 Share Posted June 27, 2017 Dencos, You mentioned a triumph project? How about a 70 bonnie? In tiger gold? I really want to have someone build this bike for my 76 year old father. It's all original and in need of a carb tune and sync some other TLC. Thoughts? Sorry, I just now saw your post. I do these restorations for my own enjoyment, It's not a full time occupation just a hobby. Sorry I couldn't help. Link to comment Share on other sites More sharing options...
beastrider Posted September 20, 2017 Share Posted September 20, 2017 I read all the posts here but could not come to a conclusion on the handlebars(need to replace the bars since I dropped my FJ right after I changed my tires ) .My bars are slightly bent to the right. I am looking for a handlebar which is as close to stock as possible. I don't want to change clutch cables,throttle cables. Currently looking at Pro taper EVO,Renthal fatbar OR should I just go with the OEM? Are the tapered EVO's direct fit? (1 1/8" at the clamp and 7/8" at the end) Any other suggestions guys? Link to comment Share on other sites More sharing options...
carey Posted September 20, 2017 Share Posted September 20, 2017 I read all the posts here but could not come to a conclusion on the handlebars(need to replace the bars since I dropped my FJ right after I changed my tires ) .My bars are slightly bent to the right. I am looking for a handlebar which is as close to stock as possible. I don't want to change clutch cables,throttle cables. Currently looking at Pro taper EVO,Renthal fatbar OR should I just go with the OEM? Are the tapered EVO's direct fit? (1 1/8" at the clamp and 7/8" at the end) Any other suggestions guys? The OEM bars are the only ones that come with the indexing holes for the control pods. The holes are easy to add to other bars. If you don't want to drill holes in your bars, you can trim the nub off the ID of the control pods. I've done to several bikes in the past. I installed Renthal Street Fighter Fatbars, whch is the same as their 450KXF dirtbike bars. Fatbars are similar dimension as OEM, but a little more sweep. Link to comment Share on other sites More sharing options...
beastrider Posted September 20, 2017 Share Posted September 20, 2017 I read all the posts here but could not come to a conclusion on the handlebars(need to replace the bars since I dropped my FJ right after I changed my tires ) .My bars are slightly bent to the right. I am looking for a handlebar which is as close to stock as possible. I don't want to change clutch cables,throttle cables. Currently looking at Pro taper EVO,Renthal fatbar OR should I just go with the OEM? Are the tapered EVO's direct fit? (1 1/8" at the clamp and 7/8" at the end) Any other suggestions guys? The OEM bars are the only ones that come with the indexing holes for the control pods. The holes are easy to add to other bars. If you don't want to drill holes in your bars, you can trim the nub off the ID of the control pods. I've done to several bikes in the past. I installed Renthal Street Fighter Fatbars, whch is the same as their 450KXF dirtbike bars. Fatbars are similar dimension as OEM, but a little more sweep. @carey, Thanks for the response. Do these Renthal bars come with inner bar end threads to mount bar end weights/hand guards? or did you get them threaded? Is the straight length sufficient enough to mount grips, control housings, and mirror/clutch-throttle? mounts Link to comment Share on other sites More sharing options...
carey Posted September 21, 2017 Share Posted September 21, 2017 The OEM bars are the only ones that come with the indexing holes for the control pods. The holes are easy to add to other bars. If you don't want to drill holes in your bars, you can trim the nub off the ID of the control pods. I've done to several bikes in the past. I installed Renthal Street Fighter Fatbars, whch is the same as their 450KXF dirtbike bars. Fatbars are similar dimension as OEM, but a little more sweep. @carey , Thanks for the response. Do these Renthal bars come with inner bar end threads to mount bar end weights/hand guards? or did you get them threaded? Is the straight length sufficient enough to mount grips, control housings, and mirror/clutch-throttle? mountsThey don't come threaded, but I threaded them my self. I bought the tap at Lowes. Yamaha bar end have the same thread pitch since at least 1986. The straight length was fine to mount at OEM components. Renthal's website has the dimensions listed. Link to comment Share on other sites More sharing options...
