richlandrick Posted January 17, 2016 Share Posted January 17, 2016 Is the a preferred switched power source under the seat for activating a relay? Link to comment Share on other sites More sharing options...
Premium Member wessie Posted January 17, 2016 Premium Member Share Posted January 17, 2016 the wire for the rear light cluster is the obvious choice for actuating the relay. Obviously, take the power feed directly from the battery. This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
richlandrick Posted January 17, 2016 Author Share Posted January 17, 2016 Thanks, Are there any unused switched factory connectors? Link to comment Share on other sites More sharing options...
Premium Member ULEWZ Posted January 17, 2016 Premium Member Share Posted January 17, 2016 Thanks, Are there any unused switched factory connectors? There are a few under the right panel (easily removed by three 1/4-turn fasteners), and 4 under the dash accessed by removing the windscreen and underlying support (easy to remove also). Check out the LED light install How To, it shows the locations. The auxiliary light connectors are switched only with the motor running. The secondary power socket is switched with just the Key on, and it what I used to run my LED relay. A government which robs Peter to pay Paul can always depend on the support of Paul. George Bernard Shaw (1856-1950) Bikes: 2015 FJ-09, Seat Concepts seat cover and foam, Cal Sci medium screen, rim stripes, factory heated grips, Cortech Dryver tank bag ring, Modified stock exhaust, FlashTune with Graves fuel map, Cree driving lights, Aux power socket. 2012 Street Triple type R (Wifes) 2007 FJR1300 (Sold!) Link to comment Share on other sites More sharing options...
Premium Member ULEWZ Posted January 17, 2016 Premium Member Share Posted January 17, 2016 Thanks, Are there any unused switched factory connectors? There are two under the right panel (easily removed by three 1/4-turn fasteners, but is for the heated grips), and 3 under the dash accessed by removing the windscreen and underlying support (easy to remove also). Check out the LED light install How To, it shows the locations. The auxiliary light connectors are switched only with the motor running. The secondary power socket is switched with just the Key on, and it what I used to run my LED relay. Here is a link: linky A government which robs Peter to pay Paul can always depend on the support of Paul. George Bernard Shaw (1856-1950) Bikes: 2015 FJ-09, Seat Concepts seat cover and foam, Cal Sci medium screen, rim stripes, factory heated grips, Cortech Dryver tank bag ring, Modified stock exhaust, FlashTune with Graves fuel map, Cree driving lights, Aux power socket. 2012 Street Triple type R (Wifes) 2007 FJR1300 (Sold!) Link to comment Share on other sites More sharing options...
