root Posted February 12, 2016 Share Posted February 12, 2016 ... I have not tried to set sag because every time I do that with stock suspension I have to end up winding in so much preload to get the sag that the spring is effectively at coil bind. ... So If I read that right, it sucks because you haven't bothered to set it up because you *know* it won't work. Got it. Link to comment Share on other sites More sharing options...
Premium Member michael Posted February 12, 2016 Premium Member Share Posted February 12, 2016 So If I read that right, it sucks because you haven't bothered to set it up because you *know* it won't work. Got it. Exactly, but just for you, I went through the useless exercise. Results were exactly as predicted. Not able to achieve desired sag on either end (about 38mm), and the ride is harsher than before. Getting a sag number by adding way too much preload just makes it stiff and causes coil bind. Springs on both ends have so much preload that they get into coil bind with very little additional travel. There is NOTHING you can do with clickers and preload to compensate for a spring that is grossly under the required rate. I have done lots of suspension setups, and I don't have to do this to know when it is futile. Fork Stock Notes After Preload 16mm Top of cap nut to top of adjuster 0mm Rebound 7 FFH FH=Full Clockwise 7 FFH Comp n/a not adjustable Unladen sag 35mm 30mm Rider sag 58mm 55mm Travel 137mm Desired Sag 34-45mm Shock Stock Notes After Preload Notch #4 Notch #7 Rebound 1.5 CCW FFH FH=Full Clockwise Comp n/ not adjustable Unladen sag 6mm 6mm Rider sag 44mm 40mm Travel 130mm Desired Sag 33-42mm Link to comment Share on other sites More sharing options...
Premium Member michael Posted February 12, 2016 Premium Member Share Posted February 12, 2016 Knew it wouldn't work before even considering buying it. Ignore the smarmy condescension (usually that's my job). Have the same issue. Never expect stock Japanese bikes to be sprung or valved to my needs but would be a bigger fan if it came with components worthy of just a respring/valving at this price point. Until upgrade one short of full preload front and rear and about in the middle on the other settings. Soft and wallowing is easier for me to "ride around" than hard/sharp. YMMV. Couldn't agree more, on all counts. Usually the smarmy condescension comes from those who are not well informed. Link to comment Share on other sites More sharing options...
root Posted February 12, 2016 Author Share Posted February 12, 2016 Knew it wouldn't work before even considering buying it. Ignore the smarmy condescension (usually that's my job). Have the same issue. Never expect stock Japanese bikes to be sprung or valved to my needs but would be a bigger fan if it came with components worthy of just a respring/valving at this price point. Until upgrade one short of full preload front and rear and about in the middle on the other settings. Soft and wallowing is easier for me to "ride around" than hard/sharp. YMMV. Couldn't agree more, on all counts. Usually the smarmy condescension comes from those who are not well informed. Just to be clear, I never professed to know anything. Quite the opposite if you've come to know me from my previous posts. Moving along now. Link to comment Share on other sites More sharing options...
Cruizin Posted February 12, 2016 Share Posted February 12, 2016 Every bike needs at least springs rated for the riders weight, sometimes a revalve too, unless u happen to weigh 165 lbs. Yamaha FZ-10 ForumYamaha FZ-07 ForumYamaha Ténéré 700 Forum Click here to go "ad free" become a supporting member and gain of bunch of forum perks! Link to comment Share on other sites More sharing options...
