deersSlayer Posted May 24, 2015 Author Share Posted May 24, 2015 Made 1/4" aluminum brackets to keep soft saddle bags away from wheel:http://i.imgur.com/fgphUuP.jpg Painted black. After a 1,500 km test (some black rubbed off at edges):http://i.imgur.com/qJu7aSH.jpg Reused stock Yamaha spacers, needed longer bolts http://i.imgur.com/lwVBYDq.jpg With RKA 50 ltr soft saddle bags:http://i.imgur.com/jw1n6uq.jpghttp://i.imgur.com/t5gqowd.jpg With Mosko Moto double end dry bag:http://i.imgur.com/ajP6Kum.jpghttp://mosko-moto.myshopify.com/collections/moto-camping-luggage/products/scout-30-rear-duffle Note the carabiner on the footpeg holder: I think the Yamaha alloy is thin and could cut a strap, carabiner is wider:http://i.imgur.com/bFsxa6T.jpg See the 2 Velcro straps:http://i.imgur.com/XkoCYOz.jpg They hold my tent poles bag:http://i.imgur.com/c2v0OcP.jpghttp://i.imgur.com/0Ihob1u.jpg Unfortunately this molle bag will not arrive in time for my trip:http://mosko-moto.myshopify.com/collections/moto-camping-luggage/products/large-m-o-l-l-e-accessory-sleeve The Molle pouch attaches to the top of the Mosko dry bag. All set for 2 weeks on the bike, including camping (I don't carry cookware.) FJ-09, 690 Enduro R. Back Roads. Period. Link to comment Share on other sites More sharing options...
quicksilver Posted May 30, 2015 Share Posted May 30, 2015 Does anyone have experience with Ortlieb Dry Bag Saddlebags? Link to comment Share on other sites More sharing options...
Premium Member fanowater Posted June 8, 2015 Premium Member Share Posted June 8, 2015 Because I prefer soft saddlebags due to their light weight, I will need to be developing a solution soon. My current thought is to remove the two sides pieces on the tail the hard luggage mounts to. Then I will make a u shape from either aluminum tubing (1/2 square, 0.06 thick wall or 1/2 wide x 1/4" thick or perhaps round). Bolt that to the sub frame and it will keep the bags from swaying into the tire area. I still strap the bags down front and rear. I did something similar to this on my Daytona and it has worked perfectly. Since I only do 2, maybe 3 trips a year, where I need enough gear to require saddlebags, I don't mind spending 10 minutes installing/removing them. Will post some pics as soon as I get something made up. I should have read all three pages, you guys are way ahead of me. Ha. Good work. Cheers 2015 FJ-09 2006 Triumph Daytona 675 Link to comment Share on other sites More sharing options...
Guest fzrcraig Posted June 8, 2015 Share Posted June 8, 2015 Has anyone with the Yamaha soft bags tried running the strap under the seat in order to take a passenger? Are there any options for these bags that would allow for a passenger (besides her sitting on the strap which I know won't go well for me)? Link to comment Share on other sites More sharing options...
vespadaddy Posted June 8, 2015 Share Posted June 8, 2015 If you don't want to spend the $$ on an AirHawk seat pad for her, perhaps you could buy a piece of sheepskin, or cut a piece out of a car seat cover. Link to comment Share on other sites More sharing options...
deersSlayer Posted July 15, 2015 Author Share Posted July 15, 2015 Made 1/4" aluminum brackets to keep soft saddle bags away from wheel: Painted black. After a 1,500 km test (some black rubbed off at edges):http://i.imgur.com/qJu7aSH.jpg Reversed the brackets (even more paint worn off after my 5K km trip in June):http://i.imgur.com/gPwHsZM.jpg Because these new 'bags' (for the KTM 690 Enduro) fit the FJ well too: http://www.moskomoto.com/collections/moto-camping-luggage/products/reckless-80l(a 20+ minute video there explains all the bag's features well) Without the MOLLE extra bags:http://i.imgur.com/8hcJlry.jpg Rear view. Left rear pocket open, right one full. Each pocket can hold 2 one-litre fuel bottles, or whatever:http://i.imgur.com/lKuQlev.jpg With the beaver tail expanded a little, and my riding jacket stuffed in there:http://i.imgur.com/jE7cMff.jpgCould expand the beaver tail a lot more, see extra strap length:http://i.imgur.com/sPGgCdY.jpg With the MOLLE bags (1 on top of beaver tail, 1 on each front of lower bags):http://i.imgur.com/bAptDgD.jpghttp://i.imgur.com/2BMdbZn.jpghttp://i.imgur.com/qX7wANq.jpg With the all bags removed (3 dry bags and the MOLLEs), and beaver tail open:http://i.imgur.com/b0W5wKL.jpghttp://i.imgur.com/Phexys8.jpg The really tiny rack work perfectly for the Reckless 80's 3 rear straps:http://i.imgur.com/XZhqIgJ.jpg FJ-09, 690 Enduro R. Back Roads. Period. Link to comment Share on other sites More sharing options...
Premium Member fanowater Posted July 18, 2015 Premium Member Share Posted July 18, 2015 So here is a picture of the soft luggage rack prototype. Still need to drill holes for using bungies to hold my tail bag in place, a drain hole per horizontal tube, prep and paint. The main tubing is 1" square and the verticals are 3/4" square. Top is 14", bottom bar is 15" (length of saddlebag) and the whole thing is 7" on the outside. Have square plastic inserts to plug each end. Each side only weighs a few ounces, 1/2 lb at the most. Currently using about 3/4 thick spacers, but may change that. Will post more pics when finished. Cheers http://s296.photobucket.com/user/daleh627/media/Rack%20Proto%20-%20resized_zpsechhulkg.jpg.html?filters[user]=143425774&filters[recent]=1&sort=1&o=0 2015 FJ-09 2006 Triumph Daytona 675 Link to comment Share on other sites More sharing options...
okietgtrider Posted August 22, 2018 Share Posted August 22, 2018 Thanks deersSlayer for directing me over to this thread. Good stuff! Much appreciated. Link to comment Share on other sites More sharing options...
