yamaham Posted March 18, 2016 Share Posted March 18, 2016 Which is the easiest way to drain gas from the tank? Link to comment Share on other sites More sharing options...
rocky5000100 Posted March 18, 2016 Share Posted March 18, 2016 Head to you local hardware store, and buy a "fluid transfer pump". It's will get the majority out. Trying to turn a tank upside down doesn't work. Ask me how I know. https://www.menards.com/main/tools-hardware/auto/maintenance-fluids/fluid-transfer-pump/tools-hardware/automotive-marine-hardware/automotive-marine-maintenance-fluids-additives-accessories/fluid-transfer-pump/p-1444421226555.htm;jsessionid=B00544E27015A5422819176C58FE397F.tndm-prodapp1-external-mcom I've got the one from harbor freight, much cheaper: http://www.harborfreight.com/multi-use-transfer-pump-66418.html Link to comment Share on other sites More sharing options...
yamaham Posted March 18, 2016 Author Share Posted March 18, 2016 Thanks, that's cheap and easy. Link to comment Share on other sites More sharing options...
Premium Member estell Posted March 18, 2016 Premium Member Share Posted March 18, 2016 Take the long way to the hardware store while using up the remaining fuel in the tank. Drive home when you have just enough fuel to get back. Arrive at home with an empty tank and a smile. :-) 2015 red FJ-09: Cal Sci screen, Sargent seat, ECU flash, slider combo, cruise, Rizoma bars, Matts forks, JRi shock, slipper clutch Link to comment Share on other sites More sharing options...
yamaham Posted March 18, 2016 Author Share Posted March 18, 2016 Riding till the tank is almost empty is nice, but at what point do you know when you have enough to make it home????? Link to comment Share on other sites More sharing options...
likebutta Posted March 19, 2016 Share Posted March 19, 2016 Get one of those motorcycle cage of deaths in your backyard. Ride the sphere until the engine gives out. But a pump would do. Link to comment Share on other sites More sharing options...
Premium Member steveb Posted March 19, 2016 Premium Member Share Posted March 19, 2016 Which is the easiest way to drain gas from the tank? Ride until it's almost empty! :-) Link to comment Share on other sites More sharing options...
Premium Member steveb Posted March 19, 2016 Premium Member Share Posted March 19, 2016 Riding till the tank is almost empty is nice, but at what point do you know when you have enough to make it home????? When the gauge starts blinking you've got at least 20 miles (I'm being pessimistic). In any event you'll have less than a gallon when it blinks which isn't very difficult to lift. Link to comment Share on other sites More sharing options...
