cretin Posted March 28, 2016 Share Posted March 28, 2016 I seem to have blown a fuse. The running lights, brake lights and horn are not working. Anyone know where the fuse for this circuit is? Link to comment Share on other sites More sharing options...
philippevanlombeek Posted March 28, 2016 Share Posted March 28, 2016 The fuse box is under the right panel, to remove it look at page 7-9 in your owner manual. The fuse is a 7,5A in the left fuse box, fisrt from the bottom (page 7-32 and 7-33). Link to comment Share on other sites More sharing options...
cretin Posted March 28, 2016 Author Share Posted March 28, 2016 Thanks!!! Link to comment Share on other sites More sharing options...
mt Posted March 31, 2017 Share Posted March 31, 2017 I have the same symptoms. My tail light, the license plate light, the horn and running lights are not working but my directional flashers do. My bike was struck from behind and got knocked over onto the right side. The front right running light was broken as a result. Funny thing is all my fuses seem to be ok. I checked them with a pin type fuse checker tool. I disconnected the panel and separated it by disconnecting the harness at the connector but no change in symptoms. I did this because the bulb receptacle was damaged in the fall and the bulb filament broken. I thought there might be a short of some sort in the bulb receptacle conductors. Anyone have suggestions where I should look solve the problem. Link to comment Share on other sites More sharing options...
caferacer Posted March 31, 2017 Share Posted March 31, 2017 I have the same symptoms. My tail light, the license plate light, the horn and running lights are not working but my directional flashers do. My bike was struck from behind and got knocked over onto the right side. The front right running light was broken as a result. Funny thing is all my fuses seem to be ok. I checked them with a pin type fuse checker tool. I disconnected the panel and separated it by disconnecting the harness at the connector but no change in symptoms. I did this because the bulb receptacle was damaged in the fall and the bulb filament broken. I thought there might be a short of some sort in the bulb receptacle conductors. Anyone have suggestions where I should look solve the problem. There is also a fuse box under the seat, as well as at least three other stand alone fuses (all close proximity) look near battery, you will find them there, try those in addition to the ones in the right side fairing. Link to comment Share on other sites More sharing options...
pedropat Posted May 2, 2017 Share Posted May 2, 2017 I'm having a similar problem. I'm putting on a aftermarket license plate holder. I conected up new turn signals and they work fine. I can't seem to get any power to the license plate light electrical wires. I've tested the light itself with another battery and it works. What's this about some additional fuses under the right fairing? Thanks Link to comment Share on other sites More sharing options...
pedropat Posted May 4, 2017 Share Posted May 4, 2017 Found the problem. The instructions on how to connect the license plates lights were totally wrong. It was blowing the the 7.5 amp fuse located under the right front cowling. Wired it up my way now everything is working normal. Link to comment Share on other sites More sharing options...
Premium Member OutlanderBC Posted May 6, 2017 Premium Member Share Posted May 6, 2017 Glad you got it solved. just in case anyone needs to know for future! There are 3 twist screws to take off the blinker fender part, two up front and one on the back, also look in behind before pulling on it to hard, it has a plastic clip/piece that can be broken if your not careful. see pic. Fuse boxes left and right Link to comment Share on other sites More sharing options...
h2focus Posted June 16, 2017 Share Posted June 16, 2017 That post saved me a lot of time hunting for my 2amp fuse today, so thank you all! Blew the fuse to the 12v plug :/. Link to comment Share on other sites More sharing options...
