FigJam-OhNine Posted February 10, 2015 Share Posted February 10, 2015 Also, note that they indicate the manual lock method described in the YouTube video in a previous post is not recommended and voids the warranty. The choice of words are very important. The bulletin states: "This modification method is not recommended. Improper cam chain tension will result in engine damage which is not covered under warranty." Nowhere does it state that the warranty is void, because it is not. Specific problems directly caused by this modification will not be covered but the warranty remains intact. That's what I meant Link to comment Share on other sites More sharing options...
Guest eatpasta Posted February 10, 2015 Share Posted February 10, 2015 After doing extensive research I've came to the conclusion that it is indeed the Cam chain tensioner. Called the local Yamaha shop and they were less than accommodating. So I called Yamaha customer service and had them call the dealership on my behalf. I now have an appointment next Wednesday. A lot of 1150GS's have this issue. It goes away when the bike warms up but many of them had to have the tensioners replaced. As far as I understand, it's more annoying than anything and a little excess chain slack wont hurt anything as long as you dont take it to redline when the engine has only been on for a few moments. Link to comment Share on other sites More sharing options...
Guest eatpasta Posted February 10, 2015 Share Posted February 10, 2015 Yes, but two wrongs don't make a right @cruizin If ya have an issue with the way that I admin the forum that I own, please send me a PM. But seriously, go post a link to this forum on that FZ-09 forum and see what happens. This is why I do not allow links to their forum here. You will notice that I allow most other links, especially to ADVrider.com, the most awesome bike forum in the entire world. amen. Link to comment Share on other sites More sharing options...
FigJam-OhNine Posted February 25, 2015 Share Posted February 25, 2015 Ugh, yeah yeah yeah, I know... "It's normal" but ugh. haha. I've tried adjusting the stock one, and it just backs right off again as soon as you put the engine under load. So that tip is fairly useless. As I put more KM's on the bike, the noise gets more constant as I assume the chain is stretching a little over time. It's like watching the best movie in the world, but the jerk next to you won't stop talking. It's still an amazing movie, but damn if that jerk isn't a distraction to your overall enjoyment. Per the comments by @cruizin, it seems you just have to bite the bullet and put in a manual CCT. Since I'm not comfortable opening up the engine, I think I may just pay a pro to do it for me. Damn this ADD, it makes my life so difficult because I can't let little nuisances go. And it becomes a borderline safety issue. If I'm distracted by the noise, I'm not focused on everything else. Anyway, rant over, and don't decide not to buy this bike because of the CCT noise. That's just silly Link to comment Share on other sites More sharing options...
robb Posted March 12, 2015 Share Posted March 12, 2015 I personally hear exactly what is being described as cam chain ticking and am not the slightest bit concerned. Heres my take after talking with a Technical Advisor from Yamaha. The stock cam chain tensioner is designed to hold the chain tight enough as to not skip a tooth and loose enough as to not wear the plastic/rubber cam chain guides and to also automatically adjust with normal stretching over time. There has never been a single failure with the stock CCT. There have been failures caused by the installation of a aftermarket manual CCT where the tensioner is set too tight against the guide causing the plastic guides to grind down and plug the oil pump strainer screen/oil filter and you know what happens after that. The ticking is going to sound differently at different temperatures, different oil viscosities and different RPM's. We all have a year or two of warranty on our bikes, I have no desire to modify a system that has 0 warranty failures. Link to comment Share on other sites More sharing options...
john2906 Posted March 24, 2015 Share Posted March 24, 2015 Any of you guys have solved the sound chain problem at the dealer? Thx for for your answer.... Link to comment Share on other sites More sharing options...
trackrider54 Posted April 1, 2015 Share Posted April 1, 2015 Own an Italian bike for awhile. Rattles and strange noises are solved with open exhausts. LOL! Link to comment Share on other sites More sharing options...
delnari Posted April 2, 2015 Share Posted April 2, 2015 Purchased an APE Manual Cam Chain Tensioner. Problem solved! Link to comment Share on other sites More sharing options...
matfj09 Posted June 6, 2015 Share Posted June 6, 2015 I have 7000 km on my bike and it just started making really bad engine noise all the time. I did all the maintenance required on the bike and i run full synthetic yamalube oil. Looks like the engine have some serious damage inside will have to call the dealer on monday to get this fixed and selll that bike. Link to comment Share on other sites More sharing options...
panooch Posted June 6, 2015 Share Posted June 6, 2015 I have 7000 km on my bike and it just started making really bad engine noise all the time. I did all the maintenance required on the bike and i run full synthetic yamalube oil. Looks like the engine have some serious damage inside will have to call the dealer on monday to get this fixed and selll that bike. Hmmm, 4,350 miles. Has to be a TC tensioner failure. Please keep us posted on the results. Everyday's a good day when your able to ride 15 FJ-09 - 2WDW ECU flash, Givi SV201, Nelson Rigg tail bag, OES sliders, Koubalink extenders, Ermax Sport, Vista Cruise, OEM seat mod, (smiles) 07 Honda ST1300A (sold) 06 Kawi KLR650 - Big Gun full exhaust, Corbin, Givi, PMR racks, carb mod (keeper) 97 Honda VFR750 - Traxxion Dynamics, Penske, Givi 3 piece, carbon exhaust (keeper?) 20+ years of snowmobiles Link to comment Share on other sites More sharing options...
matfj09 Posted June 7, 2015 Share Posted June 7, 2015 yes I will! I'm really disappointed about the bike it's only 2 months old and I need to get it fixed... I'm considering changing for a BMW R1200RT. I want a bigger bike to do some serious mileage Link to comment Share on other sites More sharing options...
jeepinoutwest Posted June 8, 2015 Share Posted June 8, 2015 Strongly suggest you give the BMW R1200RS a look. Its over 100lbs less weight and almost as tour worthy. 2001 Honda Saber - sold 2003 Yamaha FZ1 - sold 2005 Yamaha FZ6 - sold 2007 Yamaha Vstar 1300 - sold 2008 Kawasaki Versys - sold 2009 Yamaha FZ6 - sold 2010 Yamaha Raider - sold 2012 Kawasaki Ninja 1000 - sold 2014 Yamaha FJR - sold 2015 Yamaha FJ-09 - lemon back to dealer 2016 Yamaha FJ -09 Link to comment Share on other sites More sharing options...
Guest dmizer Posted June 9, 2015 Share Posted June 9, 2015 The noise is the cam chain rubbing on metal due to the excessive slack of a malfunctioning CCT, so tell your dealer he/she is full of it. This is not normal noise. There is no debating this, as this metal on metal rubbing is not normal or good. If it goes away after being warmed up, than maybe this is OK, but a constant noise is not good. There are nylon guides that the cam chain slides along. Unless the chain has completely worn through the guides, there's no way for the chain to be "rubbing on metal" since there's no metal for it to be rubbing on. If the cam chain has completely worn through the guides due to excessive slack, the noise would make it sound like your engine was about to explode. Way more than "good grief that cam chain noise is annoying." Here's a cutaway showing the cam chain and tensioner: Link to comment Share on other sites More sharing options...
Premium Member ULEWZ Posted June 9, 2015 Premium Member Share Posted June 9, 2015 The noise is the cam chain rubbing on metal due to the excessive slack of a malfunctioning CCT, so tell your dealer he/she is full of it. This is not normal noise. There is no debating this, as this metal on metal rubbing is not normal or good. If it goes away after being warmed up, than maybe this is OK, but a constant noise is not good. There are nylon guides that the cam chain slides along. Unless the chain has completely worn through the guides, there's no way for the chain to be "rubbing on metal" since there's no metal for it to be rubbing on. If the cam chain has completely worn through the guides due to excessive slack, the noise would make it sound like your engine was about to explode. Way more than "good grief that cam chain noise is annoying." Here's a cutaway showing the cam chain and tensioner: Not necessarily correct, but thanks for trying. The chain does not just go into the guides. Do you work on dirtbikes like I do? Have you ever had a cam chain noise and found the remedy? Sometimes it is just the cam chain slapping on itself or onto the tentioner. Once again, thanks for trying, but this sound is not normal, end of story. I am very versed in cct noise, that is why I say it does not sound normal. That is what I was talking about. I really don't know what your point was. Do you dispute that his engine was making a racket? Doesn't sound like mine. Thank you for the cutaway. That is useful. A government which robs Peter to pay Paul can always depend on the support of Paul. George Bernard Shaw (1856-1950) Bikes: 2015 FJ-09, Seat Concepts seat cover and foam, Cal Sci medium screen, rim stripes, factory heated grips, Cortech Dryver tank bag ring, Modified stock exhaust, FlashTune with Graves fuel map, Cree driving lights, Aux power socket. 2012 Street Triple type R (Wifes) 2007 FJR1300 (Sold!) Link to comment Share on other sites More sharing options...
Guest dmizer Posted June 9, 2015 Share Posted June 9, 2015 Not necessarily correct, but thanks for trying. The chain does not just go into the guides. Do you work on dirtbikes like I do? Have you ever had a cam chain noise and found the remedy? That posturing is not necessary to have a discussion. I have not called your experience into question here. Sometimes it is just the cam chain slapping on itself or onto the tentioner. Once again, thanks for trying, but this sound is not normal, end of story. I said nothing about the noise being normal nor abnormal. I am very versed in cct noise, that is why I say it does not sound normal. That is what I was talking about. I really don't know what your point was. Do you dispute that his engine was making a racket? Doesn't sound like mine. Thank you for the cutaway. That is useful. My point was that you indicated that the sound was metal to metal. That is extremely unlikely to be the case given the cam chain design and route through the case. To support this, I posted a picture of the cam chain cutaway. Furthermore, the sound (while bad, and annoying) is not bad enough to be a metal to metal sound. Link to comment Share on other sites More sharing options...
