surlyman Posted May 11, 2016 Share Posted May 11, 2016 Need advice on a good rear shock replacement that will support a pillion passenger that is, shall we say, a little heavy. I don't really need anything with extensive adjustments, etc., just need a shock that can support a little extra weight. Any and all suggestions will be greatly appreciated. Link to comment Share on other sites More sharing options...
Premium Member builderbob Posted May 11, 2016 Premium Member Share Posted May 11, 2016 You don't need a whole new shock if that's all you want it for. Upgrade the spring. Link to comment Share on other sites More sharing options...
surlyman Posted May 11, 2016 Author Share Posted May 11, 2016 As I am obviously not well versed in suspension upgrades, I did not know you could just upgrade the spring. Is that a DIY or something where I would need to remove the monoshock and send it to a vendor to have the spring replaced? Link to comment Share on other sites More sharing options...
Premium Member builderbob Posted May 11, 2016 Premium Member Share Posted May 11, 2016 You can buy a proper spring online. If you are comfortable with removing the shock yourself, you can take it to a shop to have the spring installed (requires special tools). Link to comment Share on other sites More sharing options...
surlyman Posted May 11, 2016 Author Share Posted May 11, 2016 Thank you very much for the information BuilderBob! Link to comment Share on other sites More sharing options...
