tracer09 Posted May 15, 2016 Share Posted May 15, 2016 Hello. A couple of days ago and after 5000 km odo my tyres needed a change, so i decided to replace them with DUNLOP RoadSmart 3. From the time i bought the bike i reached top speed many times without a pillion and never ever experienced speed wobble. NEVER. When i got out the tyre shop and ride the bike reached 170-180 km/h it was impossible to ride! i got shocked! What happened? any ideas? Link to comment Share on other sites More sharing options...
empire00 Posted May 15, 2016 Share Posted May 15, 2016 I Had this problem with a ninja 250 once. Turned out to be a bad front tire. I would go back and have the shop make sure everything is balanced correctly. Link to comment Share on other sites More sharing options...
tracer09 Posted May 15, 2016 Author Share Posted May 15, 2016 Yes but it wobbles above 170-180 which is the range that many tracer wobble... Link to comment Share on other sites More sharing options...
xlxr Posted May 15, 2016 Share Posted May 15, 2016 In rare cases, the tire has a defect such as a out of round condition or small internal tread separation that balance will not fix. Link to comment Share on other sites More sharing options...
Premium Member britelitebob Posted May 15, 2016 Premium Member Share Posted May 15, 2016 Could also be a tire not properly seated on the rim, I would take it back to the tire shop and have them sort it out asap. BLB Link to comment Share on other sites More sharing options...
Premium Member wessie Posted May 15, 2016 Premium Member Share Posted May 15, 2016 or wheel alignment - check the marks on the swingarm This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
tracer09 Posted May 16, 2016 Author Share Posted May 16, 2016 I checked the rear wheel and it was not the same line at the left. Left was in the second little line right was in the first big! Could be that the problem? The difference was too small. It os raining and i can not try to see the result. Link to comment Share on other sites More sharing options...
docsimple Posted May 16, 2016 Share Posted May 16, 2016 get a tire alignment tool and remove that possible cause. Process of elimination. Although as statted amny bikes get the head shake at high speeds 2015 Red FJ 09 2013 WR250R - little boy blue - sold 2012 DL650 V Strom - sold 2007 FZ6 - sold 1986 FJ600 - sold Link to comment Share on other sites More sharing options...
tracer09 Posted May 18, 2016 Author Share Posted May 18, 2016 I installed my old front tire and the problem seems to be better. i never though experienced a wobble before. Now is more smooth but it s there... Link to comment Share on other sites More sharing options...
mickanic Posted June 22, 2016 Share Posted June 22, 2016 Same thing happened to me. I rarely had the well known wobble in the 170/180kph range until I fitted Michelin PR4's. Link to comment Share on other sites More sharing options...
Guest dmizer Posted July 10, 2016 Share Posted July 10, 2016 I checked the rear wheel and it was not the same line at the left. Have you corrected this problem yet? Just because a wobble is on the front of the bike doesn't mean the cause is on the front of the bike. Link to comment Share on other sites More sharing options...
tracer09 Posted September 4, 2016 Author Share Posted September 4, 2016 No solution yet. Stabi makes it feel better Link to comment Share on other sites More sharing options...
Guest dmizer Posted September 4, 2016 Share Posted September 4, 2016 I checked the rear wheel and it was not the same line at the left. Have you corrected the above problem yet? If your wheels are not in alignment, the result can be a wobble, especially on a bike with very tight dimensions like this one. Also, have you talked to the shop that put the tires on your bike? Link to comment Share on other sites More sharing options...
tracer09 Posted September 5, 2016 Author Share Posted September 5, 2016 Yes. I have changed tires there 3 or 4 time with my previous bikes. Never had a problem. He agreed to put a new front tire and the problem remains. Link to comment Share on other sites More sharing options...
xlxr Posted September 6, 2016 Share Posted September 6, 2016 Maybe tire air pressure is too high, or too low. Raise the forks in the triple clamps a bit and see if that helps. Check steering head bearing for torque. Check all the other basic stuff for wobbles, it is entirely possible the problem is not the tires. Link to comment Share on other sites More sharing options...
