Cruizin
Fixing the FJ-09 Achilles Heel - Oil Drain Plug
I just picked this up at NAPA. It is a replacement part for a Mazda drain plug. Not exactly the same but suppose to work. It is a 10MM x 1.5 pitch with a 45 Tork. Will check it out next time I change oil. It has a rubber "O" Ring gasket, therefore the torque may only be required to be 10-12 lbs. (?)  Will have to check that out. If that is the case and it works, that would put an end to over torqueing the drain plugs and stripping the threads.  $3.62. FtDilUM.jpg
Niice !! I'd like to know the part number too !! Hopefully the o'ring can easily be found at Napa too
And for the torque... same as oem... good and tight and I'll have peace of mind!
Is the Drain plug M10??  I would have thought M14 (looking at pictures).  I don't particularly want to pull mine out until I'm ready to do an oil change and swap plugs
Can anyone advise the actual size (depth too)?  Thankee Kindly.
Honda SS50, Kawasaki Z200, Honda 400/4, Yamaha TDM900, Yamaha XT660Z Tenere, KTM 990 Adventure, BMW R1200GS, Mr Stevens, and my favourite of all: Yamaha MT-09 Tracer...a bit like FJ-09 only properly named :¬P
Share this post
Link to post
Excellent info. thanks for sharing. For those in the UK. Better than, and cheaper than, go to Accu.co.uk  A4 (316) Marine grade Stainless for £1.35 (Mazda is £9.28!!)
Linky Dinky
Well it seems I have to order 50.  They do have black A4 Stainless plugs in M14 size...might consider buying 50 and selling them on.
Anyone interested?
Share this post
Link to post
I did my first oil change and replaced the bolt with the mazda drain plug...but...I did not put back a washer since there was none with the oem drain plug (had no issue riding like that last season).
Do you guys think I will need to add one or should I just wait for the next oil change?
Share this post
Link to post
Its fine for now, but definitely put one in on your next oil change. There are 2 reasons to have one.
1. Helps the drain plug seal
2. The hardened steel bolt will wear on the softer aluminum casting at the mating surface creating leaks down the line. The soft copper washer will take this wear and is much easier to replace than the oil sump.
'15 FJ09
Share this post
Link to post
I don’t remember the year range but the R1 drain plug works as well. I think it was about $2-$3.
Share this post
Link to post
Just finished my beginning of the season oil change (temps in the 70s in central Ohio, woo hoo!). I went with the Mazda drain plug after the first oil change (2015) and just want to report that after three seasons and three oil changes the head of the Mazda bolt was corroded and stripped out so bad I wound up having to carefully remove it with a pair of pliers after getting the oil pan good and warm. And I've NEVER abused it. I assume the metal's too soft when tightened.
So I replaced it with the OEM bolt and will most likely NOT replace it again. It honestly doesn't hang down any lower than my Giannelli full exhaust, so shouldn't be an issue. And it will be MUCH easier to remove for future oil changes. Just wanted to share my experience as a warning to others.
Share this post
Link to post
Yeah piotrek. Agreed. An OEM part should be bulltetproof. And this part was sold as an OEM Mazda part. Doesn't appear so now. Pic attached. Gonna stick with Yamaha OEM now.
Share this post
Link to post
Yep, I just picked one up today at my local dealer... Oil drain plug from a 2016 Yamaha R1, Yamaha PN 90340-14019-00. Surprisingly cheap st $2.69 full dealer retail.
Quick & easy.
Share this post
Link to post
I've a 2015 that I picked up (used) a few months ago and just did my first oil change on. It seemed the ideal time to do the mod to the pan. I used a magnetic, hex head plug with a Dorman washer, sold for the R1, but it fit fine. Torqued to 20 lbft with a little thread sealant.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F311557082474
Share this post
Link to post
I've never used a torque wrench on any of my bikes these 40 years.
never had any problems.
granted the the only part I've never worked on is engine internals.
only on a T500 two stroke.
none have ever come loose.
Share this post
Link to post
I've never used a torque wrench on any of my bikes these 40 years. never had any problems.
I don't break out the torque wrench until I'm inside the motor or installing a motor. Swing arm too I suppose. Otherwise I prefer the German torque spec: "Guttentite"
'15 FJ09
Share this post
Link to post
Changing my oil last year on my '15, somehow the OEM pan got stripped. I say "somehow" because I think it happened on removal. I had to muscle the bolt off. I mean really give it some "umph!" (Last oil change was done by the dealer) When installing the new plug, it was turning, met some resistance, and then whoops, it just kept turning. No torque wrench, no strongarming, just a normal turning. After a lot of swearing, I bit the bullet and just ordered a new pan with the plug on the front (where it should of been in the first place). A few beers and a enjoyable afternoon, new pan was in with new plug and no issues. Not the cheapest route at all, but now I don't worry about the low spot.
Cheers!
Share this post
Link to post
That sealing washer looks a bit trick. Where do you get another one at next oil replacement? Ebay?
cb
1968 Triumph Bonneville 650
1971 Norton Commando Roadster
2002 Harley 1200 Sportster
2003 Honda ST 1300
2016 FJ 09
Share this post
Link to post
