baretta Posted July 5, 2016 Share Posted July 5, 2016 before i installed the heated grips, the throttle was fairly tight, there was little play side to side. after installed the heated grips, now i have about 1mm of play side to side. everything is installed correctly and the throttle actuates as normal, but the side to side play is very annoying. it's like there needs to be a thicker spacer between the grip and throttle assembly or between the grip and hand guard bracket. anybody else notice this? Link to comment Share on other sites More sharing options...
heffe Posted July 5, 2016 Share Posted July 5, 2016 Mine is stock, no heated grips and I have side to side play and need to find a remedy to it. "I live at the end of a 1-way dead end street" 15' Yamaha FJ-09 Matte Grey - Current 04' BMW M3 AW/BLK 6MT Slicktop - Current (Daily) 89' Mazda Rx7 Black/LS1 6MT - Current (Track car) Link to comment Share on other sites More sharing options...
rocky5000100 Posted July 5, 2016 Share Posted July 5, 2016 Mine has this too. I've just grown accustomed to it. It was annoying at first, especially since the stock throttle was good. Link to comment Share on other sites More sharing options...
baretta Posted July 5, 2016 Author Share Posted July 5, 2016 i'm probably going to remove the hand guards, so maybe i'll try to find a spacer or something to take up the extra space to reduce the play. I find the sloppy fit king of annoying. when you are moving your bike around the garage, it is especially noticeable. Link to comment Share on other sites More sharing options...
ericm Posted July 6, 2016 Share Posted July 6, 2016 Isn't the switch pod/throttle housing moveable on the bars, at least a bit? There's a locating pin to keep it from rotating but I think it can be moved around on the bars a little (once the bolts are loosened). Of course you don't want to make the throttle tube fit too tight or the throttle will bind. Link to comment Share on other sites More sharing options...
