xcsp Posted April 27, 2017 Share Posted April 27, 2017 When mine is in the lowest position, it is actually less comfortable than the stock seat. No noise or movement in the lowest setting but, unfortunately, it's not a fix option. I've trimmed the tab a little more which helps but does not eliminate the problem. May grease the tab and see if that helps. Have you contacted Sargent? Maybe they could offer some assistance. Link to comment Share on other sites More sharing options...
isteve Posted April 27, 2017 Share Posted April 27, 2017 When mine is in the lowest position, it is actually less comfortable than the stock seat. No noise or movement in the lowest setting but, unfortunately, it's not a fix option. I've trimmed the tab a little more which helps but does not eliminate the problem. May grease the tab and see if that helps. Make sure you push the seat as far back as it will go without the front tab popping out. I had this problem then noticed that the seat was in the low position at the front but hung up on the high position in the back. You'll know when it's right if there is space between the seat and the tank but very snug fit with the back seat. Link to comment Share on other sites More sharing options...
