zimbob Posted July 24, 2016 Share Posted July 24, 2016 who sells the 15 tooth sprocket Im thinking of trying one. Link to comment Share on other sites More sharing options...
Guest highplainsrider Posted July 24, 2016 Share Posted July 24, 2016 Sprocket Center. Here is the one I used: http://sprocketcenter.com/street-sprocket-applications/yamaha/fj-09-2015-2016/525-sprockets-stock-pitch/afam-21607-525-chromoly-steel-front-sprocket-yamaha-fz-8.html I like it a lot. Link to comment Share on other sites More sharing options...
Premium Member keithu Posted July 25, 2016 Premium Member Share Posted July 25, 2016 What kind of bikes have you ridden because my previous 4 (suzuki, 2 yamahas, and a Harley) did not have front wheel sensors. Huh. Chain drive bikes I've owned include a Triumph TT600, FZR750, a couple of GSX600s (US Kanotuna), and a VF750. The Yamaha, Honda, and Suzukis all had cable drive front sensors. The Triumph had a hall effect sensor on the front wheel, so no cable but still famously prone to failure. Link to comment Share on other sites More sharing options...
josh Posted July 25, 2016 Share Posted July 25, 2016 My speedo is also slow, 100km on GPS and 107km on speedo. Link to comment Share on other sites More sharing options...
adjuster Posted July 25, 2016 Share Posted July 25, 2016 I had a SpeedoDRD on my 2006 FZ1. It was internal to the transmission/final drive. No wheel sensors at all. On that bike I went down a tooth up front, and it made it much more fun around town, and was still fine on the highway. Actually make the top speed better as the engine was in it's power band in 6th v/s being beyond it. Not that we need to be riding near 150mph anyway.... I think I decided my life was worth more than finding true top speed at about 147 indicated, but it was common to glance down while passing traffic and be well over 130 in a 45mph zone.... Miss the insane top end on that bike from time to time... LOL Link to comment Share on other sites More sharing options...
adjuster Posted July 25, 2016 Share Posted July 25, 2016 Also, if you go with the Yamaha front sprocket, it's rubber isolated, so it's in theory, quiet compared to a steel only one. I think my FZ1 was using a FZ6 front sprocket. I still have the stock one on the shelf. I'll have to count the teeth, if it's one down from stock on the FJ09, that would be a viable option for someone. Link to comment Share on other sites More sharing options...
yamahafjrider Posted July 27, 2016 Share Posted July 27, 2016 My speedometer verse Garmin GPS, 0-25 mph correct, 25-50 mph speedometer +1, 50 to about 110 mph speedometer +2, somewhere about 110 mph speedometer +3. When traveling at the upper speed range, my focus is on the road not the difference between the speedometer and GPS. I have no plans on checking the difference beyond this. I also have the factory front tire, on the back I have the Dunlop Road Smart 2 in the stock size. A different model of tire may affect the speedometers reading. Hope this helps someone. Kurt Link to comment Share on other sites More sharing options...
gabefzr6 Posted July 27, 2016 Share Posted July 27, 2016 Tire circumference varies greatly with manufacturers and tire models. A quick measurement from the center of the axle to the ground with the bike upright will give you the radius. My Pirelli Rosso III rear is much taller than the stock Dunlop. 2008 Street Triple G 2015 FJ-09 Link to comment Share on other sites More sharing options...
Premium Member djbinchicago Posted August 23, 2016 Premium Member Share Posted August 23, 2016 I've never seen a chain drive motorcycle that took speed from the transmission. Every chain drive bike I've owned used a front wheel sensor for speed. Since the FJ needs wheel speed sensors for ABS and traction control, it makes sense to use that data for speedometer/odo output, too. I'm a wheelie junkie. With the traction control off I start wheelies in 1st gear and shift in the air through 2nd and someitmes 3rd gear. No way the front wheel can be the source for the speedo since I start at 35 mph and put the tire down at 88 mph when the 2nd gear rev limiter kicks in. I.m going to try two up on the rear sprocket to make 2nd gear lift the wheel a little easier. My best wheelies are on the last gallon of gas in the tank. The bike struggles with 2nd gear wheelies with a full tank. Has anyone tired 2 up on the rear sprocket? Dennis near Chicago Link to comment Share on other sites More sharing options...
Premium Member estell Posted August 23, 2016 Premium Member Share Posted August 23, 2016 I've never seen a chain drive motorcycle that took speed from the transmission. Every chain drive bike I've owned used a front wheel sensor for speed. Since the FJ needs wheel speed sensors for ABS and traction control, it makes sense to use that data for speedometer/odo output, too. I'm a wheelie junkie. With the traction control off I start wheelies in 1st gear and shift in the air through 2nd and someitmes 3rd gear. No way the front wheel can be the source for the speedo since I start at 35 mph and put the tire down at 88 mph when the 2nd gear rev limiter kicks in. I.m going to try two up on the rear sprocket to make 2nd gear lift the wheel a little easier. My best wheelies are on the last gallon of gas in the tank. The bike struggles with 2nd gear wheelies with a full tank. Has anyone tired 2 up on the rear sprocket? Dennis near Chicago I have no intention of trying it, but if you do then you'll have to shift to third gear sooner. Would you rather wheelie to 88 in second, or shift to third at a lower speed in order to get up to 88? How about adding some weight on the luggage rack to offset the weight of the fuel? 2015 red FJ-09: Cal Sci screen, Sargent seat, ECU flash, slider combo, cruise, Rizoma bars, Matts forks, JRi shock, slipper clutch Link to comment Share on other sites More sharing options...
zimbob Posted August 25, 2016 Share Posted August 25, 2016 I found the speed healer for the fj09 # sh-v4-ab-sh-u01 I ordered from blue monkey. I also have the 15t primary sprocket ordered as well.from sprocket center. I have used the speed healer before on a Suzuki that was off by 10% overstating the speed. After install it was so accurate that at 120 mph it registered 121. Link to comment Share on other sites More sharing options...
Esperance Posted November 23, 2016 Share Posted November 23, 2016 Anyone know for sure on this? My 2014 FZ09 had no ABS/TCS, so it had to be gear box based. I never changed anything on that bike but it was a few mph faster indicated than what the GPS showed from my phone. At 50 on the bike, it's more like 57 on the GPS. At higher speeds on the FZ, I was paying more attention to traffic to spend much time reading the GPS/phone that was in my tank bag's clear flap/lid. But I have not checked on the FJ09 yet. It would be very nice if the ABS sensors were used, then any gear changes would not create a need for a Speedo DRD. But it would also mean you can not get your exact MPH corrected with a Speedo DRD either. On other bikes the speedo accuracy depends on the country. USA speedos are usually accurate but here in Canada the speedo reads between 7 and 10% high. Each country has regulations about speedo accuracy so you should say where you live. Link to comment Share on other sites More sharing options...
Premium Member Brick Posted November 23, 2016 Premium Member Share Posted November 23, 2016 I'm in the USA and almost all the bikes I've ever owned had a 10% speedo error. The FJ is less more like 2 to 3%. My Super Tenere is 10%. Howard my 1999 Suzuki SV650 with a mechanical speedo is usually right on! ? Brick 2015 Yamaha FJ-09 "Red Molly" 2014 Yamaha Super Tenere' ES 1999 Suzuki SV650 Link to comment Share on other sites More sharing options...
stringman Posted December 7, 2016 Share Posted December 7, 2016 My 2015 tracer has the following: actual 100mph indicated 107mph90mph 96mph80mph 86mph70mph 75mph60mph 65mph50 54 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted December 8, 2016 Supporting Member Share Posted December 8, 2016 Is the gearing correctable on the FJ through the ECU flash? On my previous FZ1 I had the speedoDRD and when Nels flashed the ECU he asked my gearing. He changed settings in the ECU to eliminate the need for the speedoDRD. After the flash, my speedo was within 1 mph when verified with GPS. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
