stevesweetz Posted September 19, 2016 Author Share Posted September 19, 2016 Steve- You said that you removed the screen, but did you remove the adjusting mechanism? Because those 2 plastic pieces which "guide" the windscreen as it moves up or down are NEVER fully secured. Check those maybe... Skip Yup those little guide bits visibly rattling around is one of the first things I suspected, but it's not them. I jammed some shop towels around them as a test and the buzz is not coming from them. Link to comment Share on other sites More sharing options...
joese Posted October 4, 2016 Share Posted October 4, 2016 Not sure if you figured this out but I had this for about 4 days then saw my right hand guard lose from an install I did with grip puppies. May not be it but it sounded like it was coming from right under the headlights even though it was at the throtle till I tightened it. Joe Link to comment Share on other sites More sharing options...
advman Posted July 4, 2017 Share Posted July 4, 2017 Did anyone ever get to the bottom of this?? Link to comment Share on other sites More sharing options...
dbeau Posted July 4, 2017 Share Posted July 4, 2017 Here's what I do in this situation, find a quiet road that you can comfortably sustain the RPM where the buzzing starts, and just start grabbing stuff until the buzzing stops. That said, like other have said, my right handguard was buzzing a bit too. Link to comment Share on other sites More sharing options...
stevesweetz Posted July 7, 2017 Author Share Posted July 7, 2017 Did anyone ever get to the bottom of this??I didn't! I've gotten in the habit of wearing ear plugs more often, even for trips where I won't be going over 50mph. So now I don't really notice it as much - but it's still there. I thought for sure I had identified it as the black plastic trim piece on the front of the tank, but I removed that and the buzz was still there. At this point I think it's something behind the dash. Link to comment Share on other sites More sharing options...
buddha1 Posted July 8, 2017 Share Posted July 8, 2017 I had this exact issue and it drove me mad. I located it as the plastic cover to the hand guard vibrating and hitting the handguards. I stopped it by putting a little foam tape between the handguards and the coloured plastic part screwed to it. Problem completely solved for me. Link to comment Share on other sites More sharing options...
advman Posted July 10, 2017 Share Posted July 10, 2017 I had this exact issue and it drove me mad. I located it as the plastic cover to the hand guard vibrating and hitting the handguards. I stopped it by putting a little foam tape between the handguards and the coloured plastic part screwed to it. Problem completely solved for me. I've got 'barkbuster led' hand guards on mine and still got it but ear plugs definitely help, thought I'd found when I had everything off to replace the plugs as there's 2 relay boxes on the right-hand side (when sat on the bike) and they have 2 lids on them that give a plasticy type rattle when you tap them so sealed them but still no joy, i'll find it one day still a great bike.. Link to comment Share on other sites More sharing options...
buddha1 Posted July 10, 2017 Share Posted July 10, 2017 Good luck finding it. Sorry I couldn't help. These are the things that spoil iwnership Link to comment Share on other sites More sharing options...
norcal616 Posted July 21, 2017 Share Posted July 21, 2017 the headlight adjuster stems?? maybe its the ABS speed sensor making the noise when the tire speed is fast enough the air between the sensor unit and sensor plate on the rim?? maybe the buzzing is a byproduct of or combination of "harmonics" 2012 wr250f - C-class 30+ age group 2015 fz-07- Hordpower Edition-80whp 2015 fj-09- Graves Exhaust w/Woolich tune by 2WDW @120whp Link to comment Share on other sites More sharing options...
stevesweetz Posted July 21, 2017 Author Share Posted July 21, 2017 I just realized - I never checked my hand-guards. I mean, I checked them in so far as I made sure all the screws that attach them to the bike are tight, so I ruled them out based on that, but people are saying it's the painted trim piece screwed on the front of the hand-guards and I never checked that! I'm going to remove just those trim pieces and see what happens. Link to comment Share on other sites More sharing options...
treybrad Posted August 2, 2017 Share Posted August 2, 2017 I've had an annoying buzz for months that I couldn't figure out. I removed my hand guards for the summer, I've checked every bolt and tried to touch every panel I could reach while riding in the buzzy range and no luck. Sounded like it was coming from the right side of the instrument panel with my helmet on... drove me nuts! And then I discovered it was the damn clutch lever. There's just enough vertical play that it buzzes around 5-6k RPM for me. I packed a bunch of grease in the area this morning before the ride to work as a temporary fix and it was sweet silence. I'll have to find a thin nylon washer or something to create a bushing of sorts to fix it for good this weekend. trey Link to comment Share on other sites More sharing options...
aeg Posted August 7, 2017 Share Posted August 7, 2017 @trey I replaced the OEM levers with the aftermarket Chinese from a fleabay that look like a very good quality but I noticed the same vertical play of the clutch lever. I did not ride the bike after the install yet so can't comment on the buzzing. Recalled your post and I think the thin plastic washer might be a good solution. Have you tried it? Did it work for you? Link to comment Share on other sites More sharing options...
treybrad Posted August 9, 2017 Share Posted August 9, 2017 @trey I replaced the OEM levers with the aftermarket Chinese from a fleabay that look like a very good quality but I noticed the same vertical play of the clutch lever. I did not ride the bike after the install yet so can't comment on the buzzing. Recalled your post and I think the thin plastic washer might be a good solution. Have you tried it? Did it work for you? @aeg I haven't messed with it yet, probably will this weekend when I swap out my rear tire. Now that I know what it is it's a lot less annoying! trey Link to comment Share on other sites More sharing options...
stevesweetz Posted September 21, 2017 Author Share Posted September 21, 2017 Holy crap you guys, I think I finally found the source of my rattle! I was just cleaning my windshield and noticed that if I very lightly tapped on the top of the windshield, I got a momentary rattle somewhere down the dash area. 3 minutes of tapping while holding down various things later - it's the headlight angle adjusters! Just a light tap on the windshield causes the rods to vibrate against their guide bracket a little and it sounds very, very much like my 6KRPM rattle. I don't really feel like heading out again tonight, but I'm going to try jamming them up with some paper towels as a test tomorrow. Link to comment Share on other sites More sharing options...
norcal616 Posted September 22, 2017 Share Posted September 22, 2017 the windscreen brackets that are on the height adjustment slider also jiggle around all day... 2012 wr250f - C-class 30+ age group 2015 fz-07- Hordpower Edition-80whp 2015 fj-09- Graves Exhaust w/Woolich tune by 2WDW @120whp Link to comment Share on other sites More sharing options...
